Gen 1: 2004-2005 Chain length - Kawasaki ZX-10R.net
post #1 of 8 Old 03-23-2011, 06:32 PM Thread Starter
Chain length
I have searched over and over.
What length chain would be needed to run +4 in the rear with a 4 inch extension?
Mods move this id you must. Just thought I would get more feedback here.
js2787 is offline
post #2 of 8 Old 03-23-2011, 06:51 PM
BigCat for Prez!
BigCat10R's Avatar
most likely will need 150, somebody posted a link to a site that had approximations for length with extensions. and 3-6in was 150 links. mine is 7.5in with +2 in the rear and i had to cut off abt 10 links so urs wont be much diff.
BigCat10R is offline
post #3 of 8 Old 03-23-2011, 07:07 PM Thread Starter
150 seems a bit long.I also forgot to mention down one in the front.
js2787 is offline
post #4 of 8 Old 03-23-2011, 07:12 PM
BigCat for Prez!
BigCat10R's Avatar
mines -1 up front, u could try 140, but itd be close if not a lil short
post #5 of 8 Old 03-23-2011, 07:15 PM
BigCat for Prez!
BigCat10R's Avatar
the diff in price between a 140 and 150 link isnt much, better to have 2 many links than not enough ya know
post #6 of 8 Old 03-27-2011, 06:27 PM
I_RUN's Avatar
150 is probably the safest bet and cut a few links out if needed.
2004 Candy Thunder ZX-10R---GP Tech Type R wheels--520 Chain 16/41 Sprockets--Penske 8987 Shock/Spring--Revalved Front Forks--TI Force Exhaust--Galfer Brake Lines--Brembo master cylinder--EBC Pads---Yani Shiki Smoked Screen--Vortex Sliders--GPR V1 Stabilizer--Rear Fender eliminator kit--Attack Rearsets--Ivan's TRE
I_RUN is offline
post #7 of 8 Old 03-27-2011, 06:45 PM
Certified SLOW
nolaZX10's Avatar
I'm -1/+4 and 11-12" over right now and sitting with exactly 150 links. I know it doesn't answer your question, but may help you come up with a round about number.
ps - I think you will still cut some off with a 140 link, but I'm no expert.
Best 1/4mi ET: 8.98 @ 147 (stock motor, no turbo/nitrous)
nolaZX10 is offline
post #8 of 8 Old 03-27-2011, 06:49 PM
Certified SLOW
nolaZX10's Avatar
Originally Posted by GoFaster View Post
Use an on-line calculator!
http://www.botlanta.org/converters/d.../sprocket.html
For the center distance, measure the distance between the center of the transmission output shaft (front sprocket) and where you want to put the axle. For the chain pitch, use "0.625" for any nominal 5xx series chain (520, 525, 530).
edit: Stock swingarm has 25 to 26 inches center distance depending on where in the adjustment slot you want the axle to go.
Taken from: https://www.zx-10r.net/forum/showpost...2&postcount=12
nolaZX10 is offline
16T - 41T (- 1 + 2) New Chain Length muggz The ZX-10R 6 03-22-2011 02:27 PM
Chain Length and size TL1000s Performance and Tech 3 11-29-2008 11:31 AM
Chain length with -1+2??? Blink180Wilhelm Performance and Tech 10 04-11-2008 10:43 AM
chain length hollywood99 Performance and Tech 7 02-02-2007 10:14 AM
Chain length Frankyoz Performance and Tech 11 01-17-2005 03:43 PM
