Chain Guard - Kawasaki ZX-10R.net
post #1 of 29 Old 03-25-2012, 12:11 AM Thread Starter
Post Whore
-Op-'s Avatar
Chain Guard
So, I put my factory chain guard on with my extensions in place and all, and the tire wore through part of it from the the edge of the tire. anyone else have a problem like this or a solution?
-Op- is offline
post #2 of 29 Old 03-25-2012, 01:49 AM
BigCat for Prez!
BigCat10R's Avatar
I took my cain guard off a long time ago, but with the length of chain i have now i might order another.
BigCat10R is offline
post #3 of 29 Old 03-25-2012, 02:22 AM Thread Starter
Post Whore
-Op-'s Avatar
yeah, Im running it with out. I also happen to just bolt a plate with my school parking permit there and the bolts arent long enough for both, but I was trying to figure out some way to run the guard without the tire eating it.
-Op- is offline
post #4 of 29 Old 03-25-2012, 02:37 AM
BigCat for Prez!
BigCat10R's Avatar
I don't see how the tire was eatin the guard though unless something was bent
post #5 of 29 Old 03-25-2012, 02:42 AM Thread Starter
Post Whore
-Op-'s Avatar
I really dont know either. Thats why I was curious if maybe I had a problem that I was unaware of. Or maybe Im missing a spacer or something. I was thinking that might actually be the problem. When I tighten down the rear axle nut, it goes past the holes for the cotter to the point where the cotter pin isnt between the spaces of the castle nut, its just in front of the nut.
-Op- is offline
post #6 of 29 Old 03-25-2012, 02:52 AM
BigCat for Prez!
BigCat10R's Avatar
U gotta put a grinder on the spaces in the nut to make them deeper then use a hammer to beat the wrench down to keep ur in the nut so u can slip the pin thru it
post #7 of 29 Old 03-25-2012, 03:00 AM Thread Starter
Post Whore
-Op-'s Avatar
no, my problem is reverse of what youre thinking. the nut keeps going past the holes for the pin. like, the castle part of the nut goes past it. the cotter pin goes in and all with the nut on tight. Its like the nut keeps pulling the extensions closer like its pinching the back end
-Op- is offline
post #8 of 29 Old 03-25-2012, 07:22 AM
gazx10's Avatar
mine did the same. just notch it out, used a bench grinder and dressed it off with a little sandpaper. allow room for chain adj.
gazx10 is offline
post #9 of 29 Old 03-25-2012, 09:24 AM
Supercharged Mod
Tech here requires a chain guard. If you run extensions and the stock chain guard you will have to trim a little corner away (or the tire will do it for you). Tech here wanted a chain guard that went 1" past the axle (nice of them to not provide ANY information on what the rules are in advance) so I just made a new one out of some scrap sheet metal over the winter ... the shape is not very complicated, so it's pretty easy to make one.
GoFaster is offline
post #10 of 29 Old 03-25-2012, 10:48 AM
zx racer's Avatar
i just mark where the tire was hittin the chain guard and took some dikes and cut a lil piece out so the tire would clear the chain guard and wouldnt rub. now when people notice it they think i bought it that way, guess i did a good job on the cut
05 ZX-10R SWB.
zx racer is offline
Chain Guard jryanfallon The ZX-10R 1 06-02-2010 04:17 PM
Chain guard GREENninja10R The ZX-10R 10 12-24-2009 10:11 AM
06 Chain Guard or Hugger/chain guard sewman Vendors deals 1 04-21-2008 01:44 PM
Chain Guard for 04/05 10r Silent Assassin Wanted: Buy or Trade 1 04-20-2007 12:04 PM
06 10R Chain Guard sewman Pictures and Videos 16 05-07-2006 09:13 AM
