Chain for drag - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By medicbaldwin
post #1 of 7 Old 02-05-2017, 10:00 PM Thread Starter
Chain for drag
What chain are my fellow drag racers using? When I set my bike up for drag, I went to a 530 chain from the factory, due to fear of breaking a 525 with hard launches.
I currently have a 530 chain but i'm afraid when I put the swing arm on at full extension, it'll be too short, especially wity my new gearing.
Racing starts in just a few weeks
'08 10R, Lime/Black
Flashed ECU, PC5,WBC, custom shift light, shifter w/co2, cat delete, V&H slip-on, BMC race, lowered, stretched,-2/+5
MORE TO COME
medicbaldwin is offline
post #2 of 7 Old 02-06-2017, 06:57 AM
C3L1CA's Avatar
I'm currently running a Regina 520 Drag Chain and I've had good luck with it last year. It doesn't see a ton of street miles anymore, maybe saw 600 miles last year and most of those were going out to do highway pulls lol, but I had barely had any stretch and no tight spots in it. I did lube it before each track day and usually tried to lube it before riding it out to do pulls on the street but I know I sometimes forgot.
I used to run a 525 EK MVXZ and my chain and my chain maintenance wasn't as good with that and started getting tight spots in that chain.
I also run aluminum sprockets now too and aluminum sprocket nuts and that helped save a good bit of weight.
You might have to buy a chain every year if you see a lot of street miles with the regina chain as it has no o-rings but they are a pretty cheap chain.
C3L1CA is offline
post #3 of 7 Old 02-06-2017, 04:03 PM Thread Starter
my bike sees 0 street miles, strictly track. Just for my own safety and preventing tickets.
I only have 530 sprockets, so, I guess I'll stay with a 530.
Any preference of O-ring, non O-ring, X-ring?
'08 10R, Lime/Black
MORE TO COME
post #4 of 7 Old 02-06-2017, 06:27 PM
thundercoupe9's Avatar
I am using 525 zzz chain on my slow bike. If you want to stick to 530 chain and you don't street ride, go with drz2 non o-ring chain. Non o-ring chains require more maintenance, but they rob less hp due to less friction/no o-rings.
thundercoupe9 is offline
post #5 of 7 Old 02-07-2017, 06:48 AM
gazx10's Avatar
at 68 inches that drz2 chain weighed over 9 lbs. very strong but heavy. dr2 non o ring about a pound less or about same as hd 525 o ring. i run dr2 in case want to turn nitrous on, but all strong chains are heavy at 12 over.
gazx10 is offline
post #6 of 7 Old 02-13-2017, 10:05 PM Thread Starter
I was just looking at the DR2. That's the direction i'm going to go. Thanks for the info guys.
gazx10 likes this.
'08 10R, Lime/Black
MORE TO COME
post #7 of 7 Old 08-23-2017, 08:50 PM
MPac's Avatar
525 is fine. I was going 1.40's in the 60 on my gen 4, 525 is what I had, just replace your chain once a season and you'll be fine. Non o ring will be faster but not like tenths, you may see a couple hundreds, but if your running grudge or anything like that you'll be chasing thousands.
MPac is offline
Wanted: Chain 150 links and nitrous bottle mount, chain guard mrbzx7 Wanted: Buy or Trade 0 04-24-2012 08:48 AM
EK 530 Dr2 drag chain wetley Parts, Gear and Accessories 3 03-05-2012 11:45 PM
Drag Car Crash at tonights drag strip garth285 Pictures and Videos 11 01-14-2012 12:25 AM
Drag seat for Big Butt Drag racers bluedevil Strip 22 10-16-2007 10:33 PM
I WANT A GOOD DRAG STRIP SETUP FOR CHAIN AND suspension SPEEDZX10R Strip 10 08-13-2007 07:07 PM
