Gen 1: 2004-2005 chain ? - Kawasaki ZX-10R.net
post #1 of 5 Old 05-09-2011, 09:16 PM Thread Starter
tone.r's Avatar
chain ?
I hear alot of guys chains make sounds when they leave the line like there jumping links, what make them make that sound? to tight or to loose?
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 5 Old 05-10-2011, 10:15 AM
zx racer's Avatar
to loose will cause it.
05 ZX-10R SWB.
zx racer is offline
post #3 of 5 Old 05-10-2011, 10:23 AM
PatrickG's Avatar
Images: 15
My new chain only started making that noise on Friday. Thinking the same thing it must be stretching abit and loosening up.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #4 of 5 Old 05-10-2011, 10:29 AM
PearlOrange04's Avatar
Could be a lot of reasons your chain is making noise
1. too loose
2. a few links could be missing rollers
3. chain is old and stiff
4. sprockets could be worn down and teeth not catching completely
Also if your using a cheap chain lube it will come back to haunt you real quick.
You Leakin Dawg!!
PearlOrange04 is offline
post #5 of 5 Old 05-10-2011, 07:45 PM Thread Starter
tone.r's Avatar
good info
Tone.R {checkmate}
tone.r is offline
Drive Chain Swap Without Chain Tool muggz The ZX-10R 23 03-16-2011 04:25 PM
need a stock chain OR any 525 chain for this bike! mityaz Wanted: Buy or Trade 4 12-12-2009 11:19 PM
WANTED: Chain links or cheap stock chain Patrick Wanted: Buy or Trade 2 11-25-2009 10:57 AM
Chain Breaker/Chain Press TL1000s Performance and Tech 15 11-22-2008 03:44 PM
help chain and sprockets which ones are the best also a chain breaker streetfighter Performance and Tech 19 11-09-2006 06:31 PM
