busa shock - Kawasaki ZX-10R.net
post #1 of 16 Old 02-07-2011, 12:16 PM Thread Starter
codyc_13's Avatar
busa shock
I was reading somewhere that a busa shock works great for drag racing, but I was wondering if it makes a difference on the gen 1 busa shock or gen 2 busa shock. Right now I think I get get away with just the stock shock for now bit as I get more and more power traction and wheelie control are going to become an issue..
Also can you guys school me on setting up the suspension for drag racing...
From what I gather you want it to squat alot and then slowly come back up.. my question is HOW do I achive that. Do I turn the compression all the way soft and the rebound full hard? Or both full soft?
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #2 of 16 Old 02-07-2011, 03:02 PM
SlowJoe's Avatar
Buss gen 1 shock nice cheap upgrade,
SlowJoe is offline
post #3 of 16 Old 02-07-2011, 04:19 PM
KIRK_ADAMS's Avatar
I found a gen 2 on ebay for $29.00.....! just gotta take some time and watch...
Stock motor, Grudge ZX10 (( Walter White ))
https://www.facebook.com/kirk.adams.758
KIRK_ADAMS is offline
post #4 of 16 Old 02-07-2011, 05:05 PM
zx racer's Avatar
im runnin a gen 2 busa shock and its workin flawless.
05 ZX-10R SWB.
zx racer is offline
post #5 of 16 Old 02-07-2011, 06:29 PM
10R_Havens's Avatar
Originally Posted by codyc_13 View Post
also can you guys school me on setting up the suspension for drag racing...
From what i gather you want it to squat alot and then slowly come back up.. My question is how do i achive that. Do i turn the compression all the way soft and the rebound full hard? Or both full soft?
10R_Havens is offline
post #6 of 16 Old 02-12-2011, 12:17 AM
JLAudio11's Avatar
Gen 1 here, gen 2 is an even heavier spring. Basically adjust the preload like you normally would setting your sag about 1/2"-1" and then start messing with the comp and rebound till you get it where you want it. You don't want the spring set to soft and a ton of drop as that will lift the front end. You also don't want it to hard as it may not transfer weight well and just light up the rear tire. Like I said, it may take some time to to fine tune but the busa shock has more adjustment in it than our 10's do.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #7 of 16 Old 02-26-2011, 08:59 PM
mrbzx7's Avatar
Question
I gonna try one, but there was another tread that kinda made it seem like this mod was for bigger guys. I'm 145 and maybe 160 ready to ride, so gen 1 or 2 for the light weights. Or does it even matter?
mrbzx7 is offline
post #8 of 16 Old 02-26-2011, 09:09 PM
zx racer's Avatar
with your weight you should be ok with the stock shock. if you was 180 pounds or heavier i would consider a busa shock.
05 ZX-10R SWB.
zx racer is offline
post #9 of 16 Old 02-26-2011, 11:58 PM
i would get a busa shock regardless it will help im 165 and about to get one...the stock shock is too soft even with the coil turned all the way down and set on hard. You want about a 1/8 or so of play in your rear suspension...btw you dont want it squating i was told that by a guy on here who goes 1.2-1.3 60's
seanc520 is offline
post #10 of 16 Old 02-27-2011, 12:07 AM
mrbzx7's Avatar
This mod so cheap I think I'm gonna try it anyway, besides theres a million busas at the track it wouldn't be to hard to resale if it dont work.
mrbzx7 is offline
Revalved stock shock or Revalved busa shock Mad_man Strip 6 01-23-2011 07:47 AM
out with the 10, in with the busa Senior~10R The Out House 52 11-17-2009 09:30 PM
04/05 10r shock=03/04 gixxer 1000 shock? Hoser Performance and Tech 30 12-12-2006 05:10 PM
05 636 shock vs 04-05 zx10R shock Vonstallin Race and Stunt 0 09-24-2005 11:40 PM
Bad ass busa 1killer1liter Pictures and Videos 1 04-22-2005 09:14 PM
