Gen 2: 2006-2007 Broke my Clutch Basket Rivets - Kawasaki ZX-10R.net
post #1 of 9 Old 09-23-2011, 10:50 AM Thread Starter
eurichs07's Avatar
Send a message via Skype™ to eurichs07
Went to test and tune at my local track and made around 10 passes. Then I let my friend take it down the track because he only weighs 130lbs. He wheelied it and came down hard, smashing the midpipe into the oil pan. The flange pushed up into the oil pan and cracked it so it was leaking oil on the pipe. He shut it down right after the run because it was smoking pushed it back.
When we took off the oil pan there were some metal shavings and two dime size steel disks (the rivets from my clutch basket). I got lucky as hell that he cracked the oil pan because I would have never taken it off and found the rivets. They probably broke off the same run because there was hardly any internal damage. A few scratches on the case and a bolt head but nothing bad. I don't blame him for breaking it because it would have happen to me soon anyway.
I highly suggest welding your stock rivets to your basket, buying harder stainless replacement rivets, or a billet basket from Falicon to anyone who drag races. I got lucky, but this could have totally destroyed my motor!
I will be ordering a new billet basket from Falicon today and getting new rivets for my stock basket.
Video of him smashing the pipe.
Only one rivet holding the basket together.
She ain't to straight either. Could have caused some major damage if I ran it one more run!
eurichs07 is offline
post #2 of 9 Old 09-23-2011, 02:26 PM
BANNED
great..................one more thing I have to replace.......
hellboytt is offline
post #3 of 9 Old 09-23-2011, 02:39 PM Thread Starter
eurichs07's Avatar
Called Falicon and they said that they don't make OEM replacement rivets because it is a common problem with these bikes. They do sell larger diameter rivets but you have to drill your stock basket and gear. I'm just going to go with a new billet one.
post #4 of 9 Old 08-16-2013, 01:48 PM
basket failure
i have a zx-10r 2007 im tired for the second time clutch basket failure. the first time one of the three rivets failed and then caused the whole basket failure. i got a new oem basket from ebay and installed. the second time i have used the same clutch disks but i changed the first two broken i have put used clean ones. now i have the second disk broken a small piece of it and the clutch basket with three cracks on the top at the ring. i do lots of wheelies but i am smooth slipping the clutch after the first failure sometimes im agressive. now im waiting for a used basket clutch from ebay to install it.
can you please tell me the reason for the failure of the disk and basket?
joe-kh is offline
post #5 of 9 Old 08-16-2013, 02:10 PM
BigCat for Prez!
BigCat10R's Avatar
Order a billet basket from haysmachineworks.com u doing wheelies a lot is whats causing them to fracture and break. it doesn't if ur smooth on the clutch bec when it grabs its still a big jolt of force on the basket.
BigCat10R is offline
post #6 of 9 Old 08-16-2013, 03:18 PM
PatrickG's Avatar
Images: 15
I have had Tim Hays put in Hd rivets in the stock basket. 100 of runs and no issues.
https://zx-10r.net/forum/showthread.php?t=131578
https://zx-10r.net/forum/showthread.php?t=117796
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #7 of 9 Old 08-16-2013, 03:55 PM
TechX's Avatar
You could try Vance and Hines they make a lot of billet clutch stuff. Spun the rivets on my clutch hub years ago bought their Gorilla hub no more problems. They should have a beefed up clutch basket available. If you can't get on from Falicon. Also try APE or MTC or check the Schnitz site they carry everything for drag racing. I had the MTC clutch components in my super comp drag bike 363hp never had a problem. The only thing it did was destroy the inner most fiber plate after maybe 2 or 3 passes. I bought the Barnett Kevlar fibers and that solved the problem.
TechX is offline
post #8 of 9 Old 08-16-2013, 06:49 PM
Something else I keep forgetting about as well dam it bike should b done tomorrow n now in thinking about the clutch
Sent from Motorcycle.com App
beanedisel is offline
post #9 of 9 Old 08-18-2013, 02:21 AM
basket
ok thnx
joe-kh is offline
08 Clutch Basket Swag The ZX-10R 18 09-04-2017 06:36 AM
so i need a new clutch basket. where to get it and what to get cookmaster30 The ZX-10R 16 08-10-2011 06:58 PM
WTB clutch basket lildavis187 Wanted: Buy or Trade 1 06-07-2010 07:38 AM
WTB: clutch basket 04/05 10R clutch master Wanted: Buy or Trade 2 05-03-2010 09:48 PM
06/07 ZX-10 clutch basket ?? WRECKSHOP The ZX-10R 0 05-26-2009 05:14 PM
