Bottoming out issues!! - Kawasaki ZX-10R.net
post #1 of 11 Old 07-26-2012, 06:58 PM Thread Starter
Briang3a3's Avatar
Just installed my new adams straight link and when I lowered the bike back down on its tires the shock actually hit the ground and the back tire was off the ground... And by the way I have the vortex lowering links so I set it to its highest position witch if im not mistaken is only .5" lower than stock and it doesnt bottom out unless I sit on it so a little improvment but not enough clearance. I sold my stock links so I cant try them on and see if it will solve the problem but what im getting at is has anyone ever experienced this?? whats the proper (tie rods) that I would need obviously shorter ones to bring the bike back up, but I wanna make sure I get the right ones the first time because there all around $30 - $50....
P.S.
Its a gen 3 with a lowered shock.
Thanks for any advise...
Briang3a3 is offline
post #2 of 11 Old 07-26-2012, 07:32 PM
BGoodwin22's Avatar
I've been told that once I get my straight link built (similar to Adams) ill need to run hayabusa lowering links as they are shorter. I plan on getting the threades adjustable versions like I have now.
BGoodwin22 is offline
post #3 of 11 Old 07-26-2012, 07:36 PM Thread Starter
Briang3a3's Avatar
Can you please share some info on those? like a link to where I can check them out?
post #4 of 11 Old 07-26-2012, 07:57 PM
BGoodwin22's Avatar
Search "hayabusa adjustable lowering links" on fleabay. They have the threaded ends on them as opposed to being a solid link w a few holes. There are a bunch of different companies making them. I recommend going for a version w a steel body as opposed to aluminum.
Sent from my MB865 using Motorcycle.com Free App
post #5 of 11 Old 07-26-2012, 07:59 PM
BGoodwin22's Avatar
You said you had the shock shortened. Did you have it revalved and resprung also? If so, who did you have do it?
post #6 of 11 Old 07-26-2012, 08:04 PM Thread Starter
Briang3a3's Avatar
Yes had it shortened resprung and revalved for drag.
I had Trac Dynamics do it.
post #7 of 11 Old 07-26-2012, 08:07 PM
BGoodwin22's Avatar
I'm going to have mine resprung and revalved once I have time to machine the link. I was thinking Trac also but was told they didn't have much info for setting up the 10 shock for an Adams style link.
post #8 of 11 Old 07-26-2012, 08:38 PM Thread Starter
Briang3a3's Avatar
ya I asked about that but they didnt say much, so I figured Ill just mess around with the rebound and dampening untill its good...
post #9 of 11 Old 07-26-2012, 11:56 PM
mrbzx7's Avatar
You have to use short links with flat links, yall should try traxxion dynamics for the revalves. I hate dealing with Trac there slow as hell, and your lucky to even get ole dude on the phone.
Andrews Motorsports
2009 ZX10R aka "The General"
2008 ZX14R coming soon!
Paypal [email protected]
mrbzx7 is offline
post #10 of 11 Old 07-27-2012, 11:29 AM
Pimp/Player
Ripped10R's Avatar
I have the straight link and I ran into the same problem. I the vortex, soupys, and stock busa link. The busa links set my bike way to low, so I took the vortex links to a machine shop and had them make me new ones that were shorter and with the three hole for more adjustment. Cost me $30
Ripped10R is offline
fan issues SAMC Prez The ZX-10R 17 04-21-2012 06:03 PM
ZX6R Bottoming Out GreenRadar General Motorcycle Discussions 7 05-11-2011 05:15 PM
Gen 3: Pcv Issues. Baddie Performance and Tech 9 04-28-2011 06:27 AM
95 CBR 600 F3 Issues proelky General Motorcycle Discussions 2 10-02-2009 11:57 AM
bottoming out 2007 zx10 camcam22 The ZX-10R 25 05-20-2008 11:10 PM
