Gen 4: 2011-2015 Best pass but night turned bad - Kawasaki ZX-10R.net
post #1 of 11 Old 10-12-2013, 11:01 AM Thread Starter
Johnn999's Avatar
I just don't have good luck at the strip... night started great, first pass was my best pass ever. I don't think ill do any better for a long long time. Was weird i had proper slack at start of my very first, and fastest pass, then after burnout it got more slack which isn't a big deal slack changes on me but didn't have time to adjust it then suddenly i cut a great 60' lol.
But I did those four passes, plenty of time in between runs. Last run I wheelied and then they gave me the boot for going too fast without NHRA license. Talked them into letting me do short passes, did two short passes, kind of back to back, 6 minutes but only first gear passes too. But just messing around did a wheelie all of first gear on both of those for fun didn't slam down hard either but hit rev limiter.
Sat around for like half an hour left the track, went to get into it in first tire spun got into second ran out second and third then went to 6th and cruised. I really want to say it wasn't there when I started the bike up and left but then I heard a knocking noise kind of like when the bike was dropping 2 cylinders from the pcv firmware, had headphones in so sounded different i guess. Buddy said sounds like bottom end...idk what could of caused it oil just changed maybe few months ago with good stuff and bike only has 4k miles on it. But when i start the bike you can really hear it then it quiets down but still noticeable. Was really hoping exhaust leak from my pipe..but yea no.
Johnn999 is offline
post #2 of 11 Old 10-12-2013, 02:23 PM
zx-sik-r's Avatar
So it spun a bearing?
2008 ZX-10r 68" Dime Piece BST wheels
Authorized Woolich Tuner - FLASHED BY SIK
zx-sik-r is offline
post #3 of 11 Old 10-12-2013, 03:04 PM
Joel's Avatar
If you haven't experience it going into the next can tensioner if say its that. I started my motor after doing the pair valve. When I started it up I thought I'd dropped something down the butterflies. I actually thought the motor would blow!
Start it up, let it run until it's quiet then should be ok!
Joel is offline
post #4 of 11 Old 10-12-2013, 03:53 PM Thread Starter
Johnn999's Avatar
I don't know really. Never had a bearing spun but I can't see it happening on relatively new oil low mileage motor? I mean yea it has a handful of drag passes on it but still. Oil level is fine 4k miles on the bike.
I will start it up probably monday when my shop buddy comes by to lend a ear into what he thinks it is. I am really hoping it's the CCT that just failed or whatever. Talked to a few people, couple think it's spun bearing one thinks it's the cam chain but I just don't know. Really hope it's not a spun bearing...$$$$
Johnn999 is offline
post #5 of 11 Old 10-12-2013, 05:22 PM
From the way your describing it, it sounds like a CCT. It sounds identical to my buddies 2009 Honda CBR 600RR. We initially thought it was a spun rod bearing, until we tore into it. Sorry to hear about the engine trouble.
Snowblind is offline
post #6 of 11 Old 10-12-2013, 06:22 PM
Joel's Avatar
Mine lasted for about 20 seconds. I mean my motor really rattled loudly. It must sometimes get stuck in change over. I also had to blip my throttle too.
Joel is offline
post #7 of 11 Old 10-12-2013, 09:42 PM
dricked's Avatar
Drop the oil and see how it looks, if you spun a bearing you'll know. The CCT will be more of a rattle than a knock as previously posted.
dricked is offline
post #8 of 11 Old 10-13-2013, 05:29 PM
BOOSTED's Avatar
^Ya that's a good idea. You clearly need an oil change anyways lol.
Congrats on your new personal best.
2016 Ninja H2 - CANADAS Fastest 1/4 - 8.34 at 169mph - 208.4mph in the mile. Brocks Performance Stage 2 Package, MC Cycle works Intercooler, Full Polished Slash-Cut Exhaust, DNA Filter, PC5, Brocks Lowering Links, Brocks Front Strap Kit, BST Rim, Adams Performance Swingarm 7-11", Zero Gravity Corsa Windscreen, Evotech Radiator Guard, Evotech Fork Sliders, Yoshimura Tail Tidy
2011 ZX10R - SOLD
BOOSTED is offline
post #9 of 11 Old 10-14-2013, 06:21 PM
rightgreasy's Avatar
might not be a spun bearing check your clutch basket it has 3 rivets on back that tend to break off when riders start getting good 60' , just pull clutch cover and try to wiggle the whole basket note there should be no movement, i've know of atleast 7 or move thats done this
rightgreasy is offline
post #10 of 11 Old 10-15-2013, 09:23 PM Thread Starter
Johnn999's Avatar
Pulled my filter cut it open. In the grooves there are small shavings. I want to say they look like two different colors, but it's hard to tell i mean it could be the way the light is reflecting or just the way they were shaved off makes it look different. I don't suppose when I fried a clutch some of that would be what im seeing or does it not sound good?
Johnn999 is offline
Pass from last night zx-sik-r Strip 40 09-05-2013 06:47 PM
Gen 1: video of my 5.37 pass from last night cookmaster30 Strip 19 10-15-2012 10:42 PM
Gen 1: vid of my 5.75 at 128 pass from last night cookmaster30 Pictures and Videos 13 03-24-2012 10:59 PM
Rideout turned bad ! danno46 Pictures and Videos 36 06-22-2006 08:51 AM
Bad Vacation turned good! jstwkd1 The Out House 3 05-12-2006 09:25 AM
