anyone running Hook up on the street - Kawasaki ZX-10R.net
post #1 of 10 Old 12-26-2012, 07:48 PM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
I just ordered a Shinko hook up. And now kind of having second thoughts. I have had good luck with the stealth on my old gsxr 600. But figured id try a hook up for my 10r. Now I'm a little hesitant bc i ride on the street. But wanted a stickier tire for the spring time when its a little colder at the track. Anyway anyone have expierence with them on the street? I didnt want to spend the money yet for the michelin until i get useuse to the bike i didnt think i would benifit from it.
Blue08 is offline
post #2 of 10 Old 12-26-2012, 08:12 PM
BOOSTED's Avatar
I wouldn't use a Michelin for what your goals are. I wasn't a fan of mine at all. Very greasy when it was hot out, and not very confident inspiring the corners! I ended up switching to a Dunlop Q2 and I love them. Very sticky in all temperatures, and they stick for days in the corners. You don't get as much lean angle as you do with Michelin's, but I don't have the need to drag knee on the streets.
I will most likely be switching over to the Q2's again on my ZX-10r since I still do street riding, but also frequent the 1/4 mile track.
BOOSTED is offline
post #3 of 10 Old 12-27-2012, 01:24 AM
Post Whore
-Op-'s Avatar
I put a few miles on my hookup on the street. Thats usually on the way to and from the drag strip though. No good in the way of cornering, but I also have a 180/55 on a stock 10R rim, so its pretty flat and doesnt offer much lean angle.
-Op- is offline
post #4 of 10 Old 12-27-2012, 12:52 PM
zx racer's Avatar
shinko hookup isnt a very good tire for the street its to damn flat and soft ! shinko makes a 003 that is pretty sticky tire and will last while if you street ride and hookup good at the track.
05 ZX-10R SWB.
zx racer is offline
post #5 of 10 Old 12-27-2012, 11:44 PM
The hook up seemed a little greasy to me also, probably wouldn't buy one just as my street tire but a great strip tire.
Bustar is offline
post #6 of 10 Old 12-28-2012, 10:05 AM Thread Starter
Blue08's Avatar
Ive had nothing but the 003 on my gixxer and loved it for my riding. About half streethalf strip do figured might as well try the hook up. . Don't expect too many miles from it. But iy will be in the 40s up here when tracks open so i figured i could use the extra grip. Well see
Blue08 is offline
post #7 of 10 Old 12-28-2012, 10:14 AM
BratNetwork's Avatar
I bought a used stock wheel from a member on this site with the brake rotor and everything on it. I had messed with a few gearing options so I had various sprockets laying around so I put one sprocket on the wheel with the hook up for the track and a different sprocket on my original wheel with a Q2. When I want to hit the track its just a matter of swapping out the rear wheel and putting two bolts in for the front strap. Less than 30min I'm ready to go.
2008 ZX-10R | Black | Arrow Headers | AreaP Slip-on CF | K&N Filter |GUTS ECU Flash By Guhl Motors | Block-Off Plates | Fender Eliminator | Clear Alternatives Integrated Taillight | Rifleman's 1/5th Throttle Insert | Speedohealer | Pro-Grip 719s | Vortex Bar Ends | Puig Z DB Windscreen | CBR1000 Mirrors | Vortex 520 Sprockets -1/+1 | RK Gold 520 Chain | Galfer SS Lines | Pazzo Shorty Levers | Vortex Gas Cap | Rebuilt Damper | Lightech Rearsets | Much More To Come
BratNetwork is offline
post #8 of 10 Old 12-28-2012, 12:09 PM
i luv my hook up on the track and street have had no problems at all
beanedisel is offline
post #9 of 10 Old 12-28-2012, 02:18 PM
Post Whore
-Op-'s Avatar
thats what I do too. I even swap my rear rotor over though. 16/39 on the street and 16/44 on the strip gearing. Street tire is a Michelin Pilot Power and my Strip tire is the Hookup.
-Op- is offline
post #10 of 10 Old 12-28-2012, 06:01 PM
Grease Monkey Bandit
AirborneMechanic's Avatar
I toasted a hook up (200/55) this summer, wasn't great on corners and it took some effort to get it thru them but I didn't care much since I'm stretched any way, worked fine in straight line. Was flatter in the middle compared to other tires, its designed that way for a reason, hence "hook up".
Switched to the 2ct's after but might try something else next season.
Sent from my SCH-I535 using Motorcycle.com App
"Homewrecker" Gen3 custom build by ZX-SIK-R in progress.... check the build thread: https://www.zx-10r.net/forum/f28/airb...ad-140226.html
AirborneMechanic is offline
Gen 3: Help, looking to hook up PCIII 10RRdy4U The ZX-10R 4 05-27-2011 01:57 AM
Ek zzz 520 & supersprox 44t...hook me up!!?? ke2012 Wanted: Buy or Trade 3 01-20-2011 08:54 PM
anyone have a hook up on carrillos??? garth285 Vendors deals 3 11-02-2009 03:07 PM
So what's the hook? 26606 General Motorcycle Discussions 13 10-13-2009 07:02 AM
Running low psi in your pilot powers for street and track?Seems A high psi is better vizsladog Race and Stunt 18 06-04-2006 03:59 PM
