Gen 4: 2011-2015 Anyone actually using a Gen4 on the strip?? - Kawasaki ZX-10R.net
post #1 of 17 Old 07-16-2012, 12:20 AM Thread Starter
PatrickG's Avatar
Images: 15
I bought myself a gen4 and will be dragging it mostly. I've already done the Brock's clutch springs/spacer plate mod and eliminated the slipper clutch.
I have run the 1/8 mile at 6.44 at 117. 60ft 1.66
Gearing was 16/39, lowered 2" front and rear, plus strapped the frontend down.
This week I'll have the Guhl ECU Reflash back with Slipon map, Exoticycle swingarm extensions, EK 525ZZZ chain, Honda CBR1000rr shock linkage installed before racing Friday or Saturday night.
I plan on running 15/40 or 15/42 gearing.
What are some times that Gen4 riders are seeing??
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #2 of 17 Old 07-16-2012, 12:22 AM
Shift_Nashville's Avatar
15 42 would be way better...you ever been to the 1/4 track at beech bend in bowling green? Thinking bout going up there next weekend...
i could give two shits if you were taking a bubble bath in applesauce being fed grapes by lemurs with electrodes attached to your nipples in the bed of a semi truck, as long as you're not holding up traffic, go for it
Shift_Nashville is offline
post #3 of 17 Old 07-16-2012, 12:59 AM Thread Starter
PatrickG's Avatar
Images: 15
I'm about 90 miles away so it's not impossible to get down there but the local 1/8 is like 30-35 mins away. I have run my 03' gsxr1000 there last year and tried to last month but it was rained out. I'll get down there soon so it can stretch its legs..😉
PatrickG is offline
post #4 of 17 Old 07-16-2012, 01:45 AM
Gen2 Ripper
neverendingmods's Avatar
Gearing man. Since you will have it stretched definitely try the 15/42. For the 1/8th mile you need all the gear you can handle.
You had a great 60ft for stock gearing man. With 15/42 and stretched you will likely see 1.40's.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #5 of 17 Old 07-16-2012, 06:54 AM
BGoodwin22's Avatar
A local guy (Tony Ferland) has a SWB Gen4 that he is running. No internal engine work, just lowered, flashed, pipe, MR12 and a tune and that is running 8.80s in the 1/4.
Side note: did you get the chrome or gold ZZZ chain? If its chrome and you have to shorten it, let me know. I just put a longer arm on mine and need some more links.
BGoodwin22 is offline
post #6 of 17 Old 07-16-2012, 10:37 AM Thread Starter
PatrickG's Avatar
Images: 15
Sorry man, It is the gold one. I've seen your Wanted post and wanted to help but figured you wouldn't want to mix and match chains
PatrickG is offline
post #7 of 17 Old 08-13-2012, 11:48 PM
any pics of your stretched gen 4's? im about a week away from stretching mine.. im in lexington btw.
clschicago is offline
post #8 of 17 Old 08-14-2012, 04:19 AM Thread Starter
PatrickG's Avatar
Images: 15
Sure do..
ID:	164453   Click image for larger version
ID:	164454   Click image for larger version
PatrickG is offline
post #9 of 17 Old 08-14-2012, 06:23 AM
awesome
post #10 of 17 Old 08-14-2012, 08:56 AM
Bmore-stunter's Avatar
I was looking at the mods you have listed and saw that you are using CBR shock linkage. Just wanted to no if that was a cheaper way of doing a straight link?
Bmore-stunter is offline
Gen4: Gen3 rims on Gen4, anyone here done it? Joel The ZX-10R 11 06-04-2015 12:57 PM
Gen4 Abs Porhot The ZX-10R 24 05-05-2012 12:10 AM
Should I buy a gen4 Johnn999 The ZX-10R 50 03-27-2012 01:46 PM
Gen4 shinobiRide General Motorcycle Discussions 4 09-30-2011 12:36 AM
I want a Gen4 Denalithakidd The ZX-10R 15 08-27-2011 10:42 PM
