Another shock question - Kawasaki ZX-10R.net
post #1 of 10 Old 10-07-2013, 12:57 AM Thread Starter
mixedboitoo's Avatar
Here's a question for u guys that have done the busa shock on your bike......does it feel that much more stiff to you over your zx10 shock? I put my busa shock on and it feels soo stiff....with the comp all the way soft it barely "squats" an inch or so....so I switch back to the factory shock
mixedboitoo is offline
post #2 of 10 Old 10-07-2013, 08:48 AM
zx racer's Avatar
i have gen2 busa shock and dont feel its to stiff... how much do you weight ?
05 ZX-10R SWB.
zx racer is offline
post #3 of 10 Old 10-07-2013, 05:44 PM
zx-sik-r's Avatar
Ok,shock 101....just cause a shock squats doesn't mean it's working right.you want a very progressive squat...if it squats too fast it will spin or wheelie depending on track conditions,hp,etc.your weight,gear and clutch hand play huge roles in how your shock reacts.i have a 14 shock on my bike and it's worked great until I've added gear and now it's bottoming out quickly at the start so I bought a Penske.Busa shocks aren't always the answer.suspension setup takes time on a drag bike.you can't just throw a shock at a bike and make a few passes and expect it to be money.put a zip tie around the shaft of the shock and move it to the top before a pass.after your run look and see how much it moved towards the bottom,if it's on the bump stop it's bottoming out.you can try adding more spring but always remember the more spring you add the more it affects rebound..too fast of rebound will cause the bike to spin or get very bouncy down track.9/10 stock shocks off any bike will get you by but you will either need it revealed and sprung or buy an aftermarket shock.
A shock built for your setup is FUCKING amazing at the track...after it's dialed in your bike will feel like a whole new machine and you will throw that Busa shock in the garbage
2008 ZX-10r 68" Dime Piece BST wheels
Authorized Woolich Tuner - FLASHED BY SIK
zx-sik-r is offline
post #4 of 10 Old 10-07-2013, 09:55 PM Thread Starter
I'm 213 unsuited.....yea I'm familiar with the whole idea about having the susp dialed in for correct weight and no and etc but I'm just trying to figure out if I made a good move by getting this shock bc it is soo much more stiff than my stock zx10 shock
post #5 of 10 Old 10-07-2013, 10:56 PM
zx-sik-r's Avatar
Obviously you don't if that's your reply
zx-sik-r is offline
post #6 of 10 Old 10-07-2013, 11:18 PM Thread Starter
What I mean is I have 2 other bikes at my disposal with revalved shocks done by bmcracetech.....and they r ok and like u said earlier to have a bikes susp dialed in is crazy good on the track but I am just trying to see if anybody else with a busa shock if their shock is as stiff as mine?.........I agree with ur comment about u jus cant put a shock on and expect it to be money bc I think that's where I'm at now......but I also know I can't afford a Penske or a jri or a Brock's......so let me ask u this sik r.......if u had a busa shock and a stock 10 shock which would u revalve?
post #7 of 10 Old 10-07-2013, 11:33 PM
zx-sik-r's Avatar
Neither,I'd revalve a 14 shock before a Busa shock...it seems to have to much spring IMO.
zx-sik-r is offline
post #8 of 10 Old 11-07-2013, 09:42 PM
moshpete's Avatar
the spring holds up the bike. the valving just slows down the reaction to changes in forces.
moshpete is offline
post #9 of 10 Old 12-07-2013, 10:17 AM
tone.r's Avatar
I love my reval 14 shock works great for me, im 225 suited my best 60 is a 1.37 hand clutch, I hated the BUSA shock I ran gen1 and gen2 14 shock a lot better to me. I really want a big boy shock lol........
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #10 of 10 Old 12-30-2013, 05:32 PM
JLAudio11's Avatar
To the op, it seems like maybe you have to much preload on the shock. Have you set the sag? My stock 06 shock squatted to much when it was swb. It would pivot at the arm lifting the front tire rather than the whole bike lifting and pivoting off the rear tire. I switched to a gen 1 Busa shock and was much happier. I was 215-220 suited when I raced my 10. 66" wb best 60's of 1.39-1.40. I'm currently going through the same problem on my 14 and a Busa shock will not fit on it. I'm using a gen 2 Busa spring on the stock 14 shock. I think I still need a little more spring but mostly need better valving. If I launch hard enough to go 1.40 or below the bike bounces back to fast jumping all over the place.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
Busa shock question mixedboitoo Strip 5 08-14-2013 06:43 PM
shock question (dragstrip) shadyracin Suspension and Tire Tech 3 08-07-2012 04:19 PM
Gen 3: Shock question. rafa The ZX-10R 3 01-15-2011 10:45 AM
Rear Shock Question jessiah1 Performance and Tech 6 05-16-2007 02:16 PM
Penske shock question... TomSVZX10 Performance and Tech 20 07-25-2006 11:58 AM
