Almost finished with my 08 - Kawasaki ZX-10R.net
post #1 of 16 Old 06-03-2015, 07:26 PM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
Well after a long winter and a lot of parts ordered im almost done with my 08 minus the install of my co2 shifter and new wheel bearings. Last thursday I finally installed my Welded basket, Cycle Concepts drag pack clutch and Brocks clutch mod. I cant wait to get it to the strip. Im still putting off the shifter b/c im a big dummy with electronics and wireing but will knock it out soon.
Mods this winter/spring were:
AIS removal
Dyno Tune by Ryan Schnitz
DJ Multi hub with tune for 89 pump and MR12
Servo eliminator
K&N Race filter
Cycle concepts clutch
HD Springs from Cycle concepts
Brocks clutch mod
Welded clutch basket
All short velocity stacks
secondary butterflies removed
and like I said i still have to put the shifter on and install the new wheel bearings
My goals for this are 9.2 in the 1/4 or high 5.8 in the 1/8th. My best 1/8th so far was 6.02 and never really got to make a clean 1/4 pass. i weigh about 175 in gear, I think are pretty realistic goals
Here are a few pics from the clutch change last week and some random ones from when i had it torn apart
65, pos
8.67 @ 154mph
Blue08 is offline
post #2 of 16 Old 06-03-2015, 07:33 PM
PatrickG's Avatar
Images: 15
I think those are very realistic goals for yourself. Are those times on pump gas or MR 12?
Any plans on an ECU reflash?
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #3 of 16 Old 06-03-2015, 07:43 PM Thread Starter
Blue08's Avatar
when i was running the 1/8th the 6.02 was on pump gas, i was always beteween 6.0x and 6.1. ill be running the mr12 now at the track
The ecu has been flashed by Schnitz also already
65, pos
8.67 @ 154mph
Blue08 is offline
post #4 of 16 Old 06-03-2015, 08:57 PM
zx racer's Avatar
Sharp bike and nice mods man should run that no# easily!
05 ZX-10R SWB.
zx racer is offline
post #5 of 16 Old 06-04-2015, 08:43 AM
Magma05's Avatar
you wont have any trouble going .20s with that setup might surprise yourself and got a little faster. I think it has some 8.9s in the setup. Good luck
2005 Magma ZX10R
1.41 60ft 1/4 9.28 @ 141
2001 ZX6R
1.81 60ft 7.51 1/8th @ 94
2005 Cadillac CTS-V
1998 Camaro SS H/C/I Nitrous
USMC Semper Fi
Magma05 is offline
post #6 of 16 Old 06-05-2015, 05:40 AM Thread Starter
Blue08's Avatar
Thanks Zx. I hope so. All the yelling that my soon to be wife has been doing about all the time I've spent on it haha.
I'd be one happy guy to finally get an 8 sec slip. That's been the goal since I bought it. Would sure be nice to get it done this year.
65, pos
8.67 @ 154mph
Blue08 is offline
post #7 of 16 Old 06-05-2015, 07:01 PM
zx racer's Avatar
Hey just look at it this way it be all worth it when you bring home that 8sec slip😆
05 ZX-10R SWB.
zx racer is offline
post #8 of 16 Old 06-05-2015, 08:01 PM Thread Starter
Blue08's Avatar
Thanks man i just can't wait to get my year started. hopefully the drag section picks up too now that it's nice out all over the place!
65, pos
8.67 @ 154mph
Blue08 is offline
post #9 of 16 Old 06-05-2015, 08:19 PM Thread Starter
Blue08's Avatar
Still debating my gearing, I'm -1+4 but I have a 15t front (-2) I don't know if that would be too much or not.
65, pos
8.67 @ 154mph
Blue08 is offline
post #10 of 16 Old 06-05-2015, 08:28 PM
Like all your mods and everything you have done, ........except the 2 short stacks in the middle.
Good Luck on making your goals.
Boxtradamus is offline
Gen 2: Finished! abzx10r Pictures and Videos 20 10-28-2012 03:43 PM
Gen 2: All finished ..... for now :-) Chris 'FastLad' Ainley The ZX-10R 37 06-22-2012 06:47 PM
Gen 4: My ZX-10 finished....maybe drvannostrem The ZX-10R 26 04-03-2012 11:37 PM
Finished another one. nczx-10r Pictures and Videos 11 01-11-2012 07:32 PM
Almost finished. munchie General Motorcycle Discussions 9 04-04-2008 01:21 PM
