Air shifter install questions - Kawasaki ZX-10R.net
post #1 of 4 Old 04-28-2015, 08:55 AM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
I ordered the mps air shifter a couple months ago and have been putting it off b/c me and electronics do not get along at all. I ordered the electronic engil kill kit, along with the switch swapper and Coil Harness to try to make it as easy as possible. can anyone chime in with how diffucult this actually is? Ive put it off long enough and tired of it just sitting on the shelf. I think betweent the switch swapper and coil harness it should be plug and play? Im pretty sure i shouldnt have to hack into my wireing with the harness that i bought. Im mechaniclally inclined but like i said i hate anyting with wires/electronics.
65, pos
8.67 @ 154mph
Blue08 is offline
post #2 of 4 Old 04-28-2015, 04:07 PM
Magma05's Avatar
I used the MPS on my gen 1 with the schitz coil harness.. it was extremely easy you may need to splice into your horn wires to runt the switch but i dont even forsee that. If you have any questions just ask. not sure if you are on facebook or not but Zx10r Drag Tech also has alot of information
2005 Magma ZX10R
1.41 60ft 1/4 9.28 @ 141
2001 ZX6R
1.81 60ft 7.51 1/8th @ 94
2005 Cadillac CTS-V
1998 Camaro SS H/C/I Nitrous
USMC Semper Fi
Magma05 is offline
post #3 of 4 Old 04-29-2015, 08:11 AM
gazx10's Avatar
blue, just mount ur air switching valve as close to shift cyl. as possible for lowest kill times.
gazx10 is offline
post #4 of 4 Old 04-29-2015, 08:29 AM
C3L1CA's Avatar
I think the Schnitz harness came with instructions when I bought mine and MPS has really good instructions too.
I couldn't hear my horn when going highway speeds over my exhaust and never used it around town so I took my horn off and just ran my wires for the air shifter straight to the stock horn plug. So I'm not too sure how difficult the switch is but the rest of it is pretty straight forward and easy.
With the Schnitz harness and MPS kill box its a really easy setup.
I've got my solenoid right off my ram. I've read what gazx10 has said that you get best performance that way.
C3L1CA is offline
Gen 3: Air shifter/Shifter Fork issue? Please help! madkaw08 Performance and Tech 6 03-25-2014 11:07 PM
Air shifter install?? Jbundrick Performance and Tech 3 05-07-2012 09:04 AM
air shifter questions cookiedriver Performance and Tech 0 05-10-2011 06:15 PM
the difference between an Air shifter and Quick shifter Dam Fool 3000 The ZX-10R 34 10-14-2010 11:22 AM
Electric Shifter or Air Shifter??? Stud_wit_style The Out House 8 10-19-2005 06:41 AM
