525 or 530 zzz chain on my gen 1 - Kawasaki ZX-10R.net
post #1 of 15 Old 01-29-2012, 10:40 PM Thread Starter
cookmaster30's Avatar
so i have a 525 zzz chain on my 10 now and was at 12 over.
now i went 14 over and adding a 40 shot. i was told i needed to step up to a 530 setup. just checking with the pros before i spend the money to make a switch. the bike went 5.82 last year and shooting for 5.50's or so this year
cookmaster30 is offline
post #2 of 15 Old 01-29-2012, 10:45 PM Thread Starter
also aluminum or steel rear sprocket when i get to that much power
post #3 of 15 Old 01-29-2012, 10:50 PM
BigCat for Prez!
BigCat10R's Avatar
Steel rear for sure, I have aluminum now and after a handful of launches the teeth are thinning. As far as the chain goes, just check the tensile strength difference and if it's not a drastic difference go with the 525
BigCat10R is offline
post #4 of 15 Old 01-29-2012, 10:54 PM Thread Starter
i already have the 525 but my buddies are saying with my length and the nitrous i should b running a 530
post #5 of 15 Old 01-29-2012, 10:59 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
I always run steel rear sprockets and as far as the chain, if you're putting down alot of power to the ground an the bike is set up for the strip then maybe a 530 would be better but a good quality 525 will fair well to i think, especially if you have on already. cause IF you swap the chain then you'll have to do both sprockets to 530 as well.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #6 of 15 Old 01-29-2012, 11:00 PM
BigCat for Prez!
BigCat10R's Avatar
Since u'll already be hauling ass the nitrous won't be a drastic strain on the chain like it will be when u launch, but if u worried go with the 530. Only benefits are the weight savings which are pretty minute anyway
post #7 of 15 Old 01-29-2012, 11:18 PM
codyc_13's Avatar
525 would probably be fine, but I personally would go 530. I've seen what a broken chain can do, and its not pretty.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #8 of 15 Old 01-30-2012, 08:12 AM
Dragone's Avatar
Images: 11
wow, I have no experience with the strip and nos, but as mentioned, steel sprockets for a budget racer would definitely be on the setup. A good quality 525 chain though has lasted me a couple yrs now on the road course stuff, so checking the stretch of it may be more beneficial for you, since that is common maintenance anyways. I am curious now on your findings.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #9 of 15 Old 01-30-2012, 08:15 AM Thread Starter
so the tensile strength on the 525 is 10,300 and the 530 is 11,000 lbs
any of you smart mofo's know what the real world difference is
post #10 of 15 Old 01-30-2012, 08:17 AM
Dragone's Avatar
Images: 11
700lbs, do I get a cookie now? lol
hahaha, ok, my smartass comment is now behind me.
edit: On the chain and sprocket thing, I have been using the supersprox with DID gold chain to add to my previous post.
Dragone is offline
Chain and Chain Tools Info + Running an Extended Bike -Op- Performance and Tech 12 01-10-2012 09:24 PM
Drive Chain Swap Without Chain Tool muggz The ZX-10R 23 03-16-2011 04:25 PM
WANTED: Chain links or cheap stock chain Patrick Wanted: Buy or Trade 2 11-25-2009 10:57 AM
Chain Breaker/Chain Press TL1000s Performance and Tech 15 11-22-2008 03:44 PM
Chain Tensioner for 160 link chain. SAkI Wanted: Buy or Trade 0 10-13-2008 12:57 PM
