17t front sprocket @the track - Kawasaki ZX-10R.net
post #1 of 19 Old 10-06-2010, 09:44 AM Thread Starter
tone.r's Avatar
anybody running a 17t on the front for dragracing im thinking about trying a 17t, i was told biger guys a 17t will work better. I got the lower 1st. tranny gear
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 19 Old 10-06-2010, 04:22 PM
Supercharged Mod
What matters is the final drive ratio, not the number of teeth. Personally, I prefer staying with the stock number of teeth on the front sprocket and do all the ratio changing with the rear sprocket (and the length of the chain) ... it puts less stress on the chain, and it reduces the tendency of the chain rubbing on the plastic guide on the swingarm.
GoFaster is offline
post #3 of 19 Old 10-06-2010, 06:07 PM
zx-sik-r's Avatar
ok ima try and help you with this but its gona take some questions answers...ok.your a heavy dude,what kinda hp does the bike put down?wheelbase?are you spraying it?1/4 or 1/8
zx-sik-r is offline
post #4 of 19 Old 10-06-2010, 07:43 PM Thread Starter
tone.r's Avatar
215 suited ,175 hp 84tq, 64'', all motor NO NOS, lower first gear in tranny, forks cut down 2'' rear shock re-valve, I run 1\4 best MPH with 16t 43t 151mph trapping in 5th gear about 8500rpms, best et with 16t 44t but im about 2 bike from trapping bumping the rev limiter. Thanks
Tone.R {checkmate}
tone.r is offline
post #5 of 19 Old 10-06-2010, 07:54 PM
zx-sik-r's Avatar
Originally Posted by tone.r View Post
215 suited ,175 hp 84tq, 64'', all motor NO NOS, lower first gear in tranny, forks cut down 2'' rear shock re-valve, I run 14 best MPH with 16t 43t 151mph trapping in 5th gear about 8500rpms, best et with 16t 44t but im about 2 bike from trapping bumping the rev limiter. Thanks
the only prob i see is that your gear is too tall if your only trapping 5th,you wana almost be at the end of 6th.that short first gear is meant so that you dont have to run a short gear...maybe a 15-42?the bike seems like its making good power to be running that mph with your weight.i wish i ran 1/4 more so i had a bit more knowledge on this.ive heard good and bad about the short first gear...some guys love it and others say its worthless
zx-sik-r is offline
post #6 of 19 Old 10-06-2010, 09:00 PM Thread Starter
tone.r's Avatar
im trying 16t 46t tomow, that should put me at the top of 6th
Tone.R {checkmate}
tone.r is offline
post #7 of 19 Old 10-07-2010, 10:54 AM
IMO
U dont want to trap in 6th, 5th is the gear u want to trap in(on motor). Why? 1 extra shift and u leave no room for more hp trapping in 6th.
06green is offline
post #8 of 19 Old 10-07-2010, 03:51 PM
codyc_13's Avatar
Imo you want to be at the top of 5th. If the 16 44 has you almost at the limiter try 17 46 that should put you about 12 grand in 5th
codyc_13 is offline
post #9 of 19 Old 10-07-2010, 04:46 PM
KIRK_ADAMS's Avatar
I asked RG about what gear we should be going through the traps in....he told me top of 6th.....I went from trapping in the top of 5th to the top of 6th and it helped a bunch.
Stock motor, Grudge ZX10 (( Walter White ))
https://www.facebook.com/kirk.adams.758
KIRK_ADAMS is offline
post #10 of 19 Old 10-07-2010, 04:53 PM
Bike makes more tq in sixth...
Stay away from a small front sprocket, 16 if you have to, 17 is even better. I'm going to an 18 soon enough actually.
Patrick is offline
sprocket set up for track days ? soxxerms Performance and Tech 13 11-25-2008 08:48 AM
OEM 2006-07 ZX10R Chain,front sprocket,rear sprocket, and Pirelli Dragon front tire Killerzxrider Parts, Gear and Accessories 0 09-26-2008 05:25 PM
front sprocket help hollywood99 The ZX-10R 9 09-08-2007 11:39 AM
front sprocket 1BADASSZX10 The ZX-10R 8 03-28-2007 07:42 PM
Best sprocket for the track Daveszx10 The ZX-10R 5 06-02-2005 10:42 AM
