15/45 gearing - Kawasaki ZX-10R.net
post #1 of 32 Old 05-17-2010, 08:38 PM Thread Starter
M109R's Avatar
15/45 gearing
Anybody ever try running this gearing 15/45? Got a 07 10 have Muzzy pipe, air shifter, 66" stretched, Bmc Filter, 93 pump gas, and Slammed to the ground and also weight 200 lbs suited. Gonna be switching tires out to a 120/60/17 shinko front and a 190/50/17 shinko u soft
M109R is offline
post #2 of 32 Old 05-17-2010, 09:44 PM
JLAudio11's Avatar
Man I'm 15/43 and 195 unsuited. I'm actually goin the other direction. Once you shift thats a small rpm window that its runnin in and not necessarily makin good use of everything you have.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #3 of 32 Old 05-17-2010, 09:56 PM
codyc_13's Avatar
I'm at 16/46 and in my opinion it is to much I'm going to a 16/44. I don't think you will have enough gear if you are running 1/4 mile. I'm on the rev limiter going through the traps
codyc_13 is offline
post #4 of 32 Old 05-18-2010, 04:11 AM Thread Starter
M109R's Avatar
I am 16/44 now going through the traps in 4th also running a 530 chain and sprocket set up and still on stock tire 190/55/17.
M109R is offline
post #5 of 32 Old 05-18-2010, 11:08 AM
codyc_13's Avatar
Your at 16/44 and you are going through the traps in 4th....that doesn't sound right to me????
codyc_13 is offline
post #6 of 32 Old 05-18-2010, 11:25 AM
codyc_13's Avatar
Count the teeth on your front sprocket I bet your at 17/44
codyc_13 is offline
post #7 of 32 Old 05-18-2010, 07:46 PM Thread Starter
M109R's Avatar
Nope its 16/44 i just checked it tonight and i'm going thru the traps in the top of 4th gear
M109R is offline
post #8 of 32 Old 05-18-2010, 08:36 PM
codyc_13's Avatar
Hmm that's interesting... What's is your mph? Unless I'm just mixed up a 16/46 your put your top speed about 146 or 147 mph.
codyc_13 is offline
post #9 of 32 Old 05-18-2010, 08:44 PM Thread Starter
M109R's Avatar
I am Running 9.50's @ 149-150 i just can not get the bike to 60 at all lately 1.60-1.64 that's why i am gonna play around with gearing on this bike. Now i am still running the stock tires but just picked up a shinko u soft for rear in a 190/50/17 and a 120/60/17 shinko front.
M109R is offline
post #10 of 32 Old 05-18-2010, 11:23 PM
quikgix's Avatar
what rpm are you leaving at? I run 16-43 on my10R and it goes 1.48-1.52 60's goin 9.20-9.30 I'm leaving at around 9K and I weigh 185 unsuited.My buddy nick is 220 and he 16-44 and he does 1.52-1.56 60's and 9.40-9.50's
Now what
quikgix is offline
1/4 Gearing Help M109R Strip 22 02-16-2010 06:26 AM
??? Gearing 06-07 NinjaRider...JDP Performance and Tech 4 08-17-2009 01:31 PM
gearing xtremest101 Strip 3 05-14-2009 08:22 AM
Gearing?? 04-05 appocalypse Strip 10 03-18-2008 03:06 PM
gearing hollywood99 Strip 11 01-06-2007 10:27 PM
