1/4 Gearing Help - Kawasaki ZX-10R.net
post #1 of 23 Old 07-29-2009, 08:52 PM Thread Starter
M109R's Avatar
1/4 Gearing Help
Hey all, I'm running a 07 ZX10R stock motor, M10 exhaust, PC3, BMC filter, lowered, extended(67"), and 530 chain. 16/44 gearing went 9.48 @ 151 with bad 60. Changing out to a 15/ 42 or 43. Any one try this at all suited weight of 195.
M109R is offline
post #2 of 23 Old 08-26-2009, 09:18 PM
tone.r's Avatar
what was your 60/ and your 330?
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #3 of 23 Old 08-27-2009, 04:25 PM Thread Starter
M109R's Avatar
60'- 1.583, 330'- 4.165, 1/8- 6.227 @ 119.79, 1000- 8.013, & 1/4 9.507 @ 151.66 that's lowered, extended, pipe, air filter and just a throw in map, foot shifting cause i cant get air shifter to work right Gearing was at 16/44 now i just put a 15/44 on but haven't had a chance to get to a test and tune yet
M109R is offline
post #4 of 23 Old 08-27-2009, 04:31 PM
10 ninja r's Avatar
on an extended bike the combo is -2/+2 good luck
06 zx-10r MPS nos kit (40 dry)NOS mini controller , Brocks ex (Full undertail system) Piper cross (Air filter) PowerCommander 111 HUB and Quickshifter Carrozzeria v-star rims(HPC map and tune) 2011 zx-10r Austin vr 250 mm pipe, Guhl reflash, bazzaz self map w/ quick shifter, Bmc carbon race filter,attack rear sets,driven sprockets -1/+1 OZ racing wheels. Special Thx GUHL MOTORS,HOUSE OF SPEED 2011 lexus is-f
10 ninja r is offline
post #5 of 23 Old 08-27-2009, 07:12 PM
tone.r's Avatar
Man thats damn good and your foot shifting you must be about 135lb lol, keep up the good work
Tone.R {checkmate}
tone.r is offline
post #6 of 23 Old 10-12-2009, 04:18 AM
Air shifter help
If you need help with your air shifter set up pm me & I will give you a call. I use MPS & Muzzy digi kill.
okhaze is offline
post #7 of 23 Old 10-12-2009, 07:58 PM Thread Starter
M109R's Avatar
9-19-09 with a 15/44 set up bike went
60. 1.587
330. 4.143
1/8. 6.259
Mph. 115.66
1000. 0000
1/4. 9.645
Mph. 145.79
I just switched the gearing out to a 15/43 to try but haven't had time to get the bike back to the track. Also want to try and get the air shifter figured out.
M109R is offline
post #8 of 23 Old 10-12-2009, 09:16 PM
Vince10R's Avatar
60. 1.587
330. 4.143
1/8. 6.259
Mph. 115.66
1000. 0000
1/4. 9.645
Mph. 145.79
where did all the mph go? everything up to the 1/8 was damn near the same but mph was down a lot. did you change anything besides the gear or are you having problems getting wot with the extra gear or missing shift points?
Vince10R is offline
post #9 of 23 Old 10-13-2009, 06:46 PM Thread Starter
M109R's Avatar
I forgot to add that I change map for m10 pipe not sure if that factored any thing. I will be taking lab top with me to play around with a couple of maps & also got some gearing to play around with. I was upset that I lost a lot of MPH. Once I get air shifter figured out since it goes thru PCIII I want to try and find some one to dyno n get everything work to notch.
M109R is offline
post #10 of 23 Old 10-13-2009, 06:53 PM
Shorty's Performance
madnessracing's Avatar
you should go back to the old map you had when you ran 151mph!! I dont think your gearing is the problem! I think all you have to do is be more aggressive on the clutch!
madnessracing is offline
gearing??? mdihotmale The Out House 20 05-16-2008 10:38 AM
Gearing TurningPoint ZX-6R & ZX-6RR Archives 5 03-16-2006 10:01 AM
16/41 gearing DANGER10R Race and Stunt 5 02-06-2006 08:25 AM
gearing... what is what? Nick.INF Performance and Tech 10 02-02-2006 12:48 AM
gearing? TC24 Performance and Tech 21 01-24-2006 08:16 PM
