05 zx10r thin gasket and cams - Kawasaki ZX-10R.net
post #1 of 11 Old 07-06-2010, 05:10 PM Thread Starter
gbillzx10r's Avatar
i am putting a thin head gasket on the bike and was wondering if i should do the cams while i am in their, if so what should do for cams????? is their another year zx10 that will work and give me power, if not what ones would work....i ride the bike to and from work about two to three times a week and hit the local 1/4 mile track about 3 times a month just to let yall know what i do with the bike....thanks bill
NHRA # 286
2005 zx10r full muzzys system, lowered, stretched a few inchs, cycle concepts drag pak(the Best), air filter, sec. flies out, and a tune cycle-tek air shifter
gbillzx10r is offline
post #2 of 11 Old 07-06-2010, 09:33 PM Thread Starter
gbillzx10r's Avatar
ok i think i found it .........thin head gasket with the 08 stock intake cam and 04-05 stock exh cam should be good what numbers for the deg should i do????? 109/110 ?????.......its a 05 zx10 streched lowered pc3 geared race filter butterflies out, all short stackes, with a air shifter.
NHRA # 286
post #3 of 11 Old 07-06-2010, 10:00 PM
JLAudio11's Avatar
Actually you should get the 08 kit or race intake cam. It runs about $140. Kawi part # 49118-0134. I dont have cam numbers though as I haven't done this yet but others that do know should chime in. Or try a search.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #4 of 11 Old 07-14-2010, 11:51 PM Thread Starter
gbillzx10r's Avatar
please help
someone
NHRA # 286
post #5 of 11 Old 07-15-2010, 10:02 AM
dsabat's Avatar
For dragracing, try 106/106 with an 08 race intake and stock exhaust cam.
dsabat is offline
post #6 of 11 Old 07-15-2010, 03:42 PM Thread Starter
gbillzx10r's Avatar
ok i will try that, thank you
NHRA # 286
post #7 of 11 Old 09-04-2010, 10:17 AM
roby1217's Avatar
so is it 49118-0034 OR 49118-0134? I am confused
Yoshimura TRC slip ons, PC III, Sato sliders, Zero Gravity DB screen...
roby1217 is offline
post #8 of 11 Old 09-04-2010, 09:19 PM
JLAudio11's Avatar
49118-0034 is the old Kawi race cam for the 04-07. It is no longer available. 49118-0134 is the 08+ Kawi race cam and the one you should be able to get from your local dealer or online.
post #9 of 11 Old 09-04-2010, 09:24 PM
roby1217's Avatar
thanks! I assume it is a direct fit?
roby1217 is offline
post #10 of 11 Old 09-04-2010, 11:40 PM
dsabat's Avatar
Yes, it will fit all years.
dsabat is offline
04-07 ZX-10r Kawi Race cams, thin head gasket and race springs heads up!!! garth285 Parts, Gear and Accessories 4 07-24-2008 10:03 AM
piston or cams\thin gasket tone.r Performance and Tech 35 12-06-2007 01:40 AM
I Need 04 zx10r thin head gasket on1whl Vendors deals 1 03-04-2007 09:27 AM
thin head gasket,race cams, adj cam sprocket? mysticZX10 Performance and Tech 29 11-04-2006 09:25 PM
Thin head gasket, bigger intake and exhaust cams, 1killer1liter The Out House 12 04-28-2006 06:12 PM
