Gen 4: 2011-2015 Waterproofing Harness Plugs? - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Pedestrian
post #1 of 8 Old 03-23-2016, 02:05 PM Thread Starter
doitda's Avatar
So I've turned my Gen4 into a dedicated track bike and removed the front light and front turn signals.
Does anyone know of some harness plugs to fit into the open spots where the lights used to connect?
Just thinking I want to block out condensation of the open harness plug connectors.
Thanks,
Chris
doitda is offline
post #2 of 8 Old 03-23-2016, 03:12 PM
Fill with dielectric grease.
evallarta1 likes this.
Pedestrian is offline
post #3 of 8 Old 03-23-2016, 06:37 PM
nakedinseattle's Avatar
That.
and then, you can buy caps/covers for the connectors too. or just wrap electrical tape over the top.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #4 of 8 Old 03-24-2016, 10:13 AM Thread Starter
doitda's Avatar
Thanks, will definitely do the dielectric grease.
Still have some leftover from a Jeep spark plug change.
For buying caps/covers, would that be something that Autozone would have? If an internet order, have any links to a few examples?
Thanks
doitda is offline
post #5 of 8 Old 03-24-2016, 10:25 AM
evallarta1's Avatar
Like everyone else mentioned, dielectric grease.
Velocity Calibrations
evallarta1 is offline
post #6 of 8 Old 03-24-2016, 05:49 PM
Originally Posted by WhatARush View Post
for caps, I cut the fingers off nitrile gloves. wrap them around the plug, then zip-tie it to make sure they don't come off
also a good solution
Shut up and ride.
post #7 of 8 Old 03-25-2016, 06:27 PM Thread Starter
doitda's Avatar
Nice suggestions.. Thanks guys!
I should be set now.
doitda is offline
post #8 of 8 Old 03-25-2016, 08:53 PM
Judge Dredd Mod
mr_honez's Avatar
I've used oversized caps held down with heat shrink tubing. It's tougher than rubber gloves, but takes more time to install. Fill plug with dielectric grease, put cap over plug, slide heat shrink tube over cap/plug and shrink it making sure to cover the cap to plug harness. Works well for longer periods.
BURNOUT.....
mr_honez is offline
Gen4 US harness into UK harness how to do it??!! ISHAQALI Performance and Tech 2 07-09-2015 07:04 AM
Gen 4: Want to trade us harness for eu harness ISHAQALI Wanted: Buy or Trade 0 07-09-2015 06:10 AM
Gen 1: 004 2005 04 05 Wiring harness and sub harness's 2 bobjoe Wanted: Buy or Trade 2 03-17-2013 04:08 PM
plugs elitejstn39 The ZX-10R 6 11-20-2008 06:52 PM
Plugs mattfr12 Performance and Tech 0 01-14-2007 02:31 AM
