Track bike maintenance - Kawasaki ZX-10R.net
post #1 of 3 Old 09-02-2014, 01:47 PM Thread Starter
How often do you guys check the valves and service your front and rear shocks on your track bikes? Once a season? Less? Now that I'm getting a little faster I am starting to wonder these things. Other than oil changes, what other things should I pay attention to that may need to be done before the suggested service interval? I usually run mid-pack in the B group.
rgprestige15 is offline
post #2 of 3 Old 09-02-2014, 04:35 PM
dricked's Avatar
Valve clearance check once a season, suspension refresh once a season (depending on mileage) all bearings greased once a season, calipers cleaned every weekend, brake fluid flush twice a season.
dricked is offline
post #3 of 3 Old 09-02-2014, 05:27 PM
kman0066's Avatar
All sounds good.
Add to that:
1.) Check bolts for tightness every day.
2.) Keep the battery on a tender
3.) Lubricate the shifter and brake levers a few times per season, especially after rain events.
4.) I like to take the air filter out every couple races and beat out all the bugs and tire chuncks stuck in it. I clean it with the cleaner twice per season.
5.) If you're running straight water + water wetter, flush it out once per season. Stock stuff, just run the recommended manual length.
6.) Spark plugs I change at the recommended manual setting or once per season, whichever happens first.
7.) Check your brake pads daily. As you get faster, you'll find those wear out a lot quicker and quicker.
8.) You'll also want to check your chain length more regularly. It will stretch quicker.
WERA Expert #43
2012 WERA National Challenge Series Open Superstock Novice Champion
http://maps.wera.com/racers/racerpro...30532136163864
COMET RACING LEATHERS
2011 ZX-10R Race bike (Vortex, Silkolene, Leatt, Yoshimura, BRIDGESTONE)
2013 ZX-6R 636 Race bike
2008 Ducati Hypermotard 1100s
kman0066 is offline
Aussie bike converted to track bike. Gum The ZX-10R 4 01-20-2014 04:12 AM
Gen 3: Maintenance Crescent1101 The ZX-10R 3 10-09-2013 05:43 AM
Maintenance ?'s bcm0018 Performance and Tech 2 11-16-2008 09:42 PM
How many of you do your own bike maintenance 06450F Performance and Tech 37 12-23-2006 01:43 PM
CO Maintenance ctg1177 The Out House 0 08-20-2006 01:35 AM
