Gen 4: 2011-2015 stock tip over switch location.. - Kawasaki ZX-10R.net
post #1 of 9 Old 11-02-2014, 11:11 PM Thread Starter
For those of you NOT using the kit ecu, did you leave the black bracket in there along with the rear seat latch?? yes i did search, a few different things
J_fuggin_t is offline
post #2 of 9 Old 11-04-2014, 07:13 PM
Always On Mod
Animal11's Avatar
nope, i pulled the seat latch bracket out, and then zip tied the tip over switch to the fuse block that sits by the ecu
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #3 of 9 Old 11-05-2014, 11:28 PM
ricky218's Avatar
I removed the bracket and drilled two holes in the center of the in the subframe and bolted it down.
ricky218 is offline
post #4 of 9 Old 11-06-2014, 08:42 AM Thread Starter
i was just looking at that very same thing last night, i was curious if it would hit the bodywork or not, i'm assuming not.
post #5 of 9 Old 11-06-2014, 08:51 AM
I drilled it too but put it on the back side of the subframe.
cajun636 is offline
post #6 of 9 Old 11-06-2014, 08:59 AM Thread Starter
Thanks for confirmation that will work. Appreciate it.
Mod list: GP 25mm front cartridge kit / JRi piggyback triple shock / attack rear link / Brembo RCS / Galfer SBK lines / Austin Racing GP2r / BMC Race Filter / Yosh Case Savers / Vortex Clip ons / Vortex Rear sets / Vortex Keyless Gas Cap / Lighttech Chain adjusters w/ Fast Frank Quick change / AIM solo DL data logger / motion pro throttle / KIT ecu & Harness / Moto XP Ricambi Bodywork / Puig Double Bubble /
post #7 of 9 Old 11-06-2014, 04:26 PM
ricky218's Avatar
Yep, you should be good to go!
ricky218 is offline
post #8 of 9 Old 11-11-2014, 03:11 PM Thread Starter
Name:	ImageUploadedByMO Free1415740243.560738.jpg
Name:	ImageUploadedByMO Free1415740286.074342.jpg
Here's some pics for the next guy.
post #9 of 9 Old 11-11-2014, 10:17 PM
ricky218's Avatar
nice, good work
ricky218 is offline
oil pressure switch location bond750 The ZX-10R 15 10-05-2017 07:21 PM
Gen 1: HOW TO DISABLE TIP SENSOR AND kS SWITCH??? mosh69 The ZX-10R 1 08-23-2013 08:43 PM
Gen 3: Stock damper and right handle with switch vinceblkcls Parts, Gear and Accessories 4 05-13-2012 10:41 PM
Tip over kill switch revbbrc.com Performance and Tech 9 09-08-2007 01:14 AM
rearsets using stock brake light switch on1whl Performance and Tech 4 03-06-2005 03:20 PM
