Gen 1: 2004-2005 Removing ignition and wiring. - Kawasaki ZX-10R.net
post #1 of 4 Old 11-10-2014, 01:26 PM Thread Starter
JoekZX10r's Avatar
Any help is appreciated. I wanna make my 10r track only. And wanna make it keyless!! Removing ignition and such seems easy. But how to I bypass it for the ecu and such??? And rewire kill switch an starter? Thanks in advance.
JoekZX10r is offline
post #2 of 4 Old 11-10-2014, 01:52 PM
Grease Monkey Bandit
AirborneMechanic's Avatar
Touchy subject right there, although I am in the same boat, probably not wise to post this type of a topic on a public forum, can potentially be used by the wrong person to do the wrong thing. If admins allow it, someone may be able to pm you regarding this but would probably check with them on this.
AirborneMechanic is offline
post #3 of 4 Old 11-10-2014, 01:55 PM Thread Starter
JoekZX10r's Avatar
Yea understand......I assume its not that hard. Just added wiring and weight I don't need and would like to do without it.
post #4 of 4 Old 11-10-2014, 01:56 PM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
Message me I will show you.
Bear Jew
Hernando is offline
ignition wiring questions norcal10 Performance and Tech 3 11-26-2010 09:36 AM
Ignition Switch Wiring mach_man_187 The ZX-10R 8 12-10-2008 03:27 PM
ignition switch wiring motoguru The ZX-10R 2 10-10-2008 11:45 PM
Removing ignition? Bigtuna660 The ZX-10R 2 08-25-2007 01:30 AM
Removing the Tail Light & signal wiring? RichTJ99 The ZX-10R 1 09-10-2005 12:08 AM
