Gen 4: 2011-2015 relocating the voltage regulator??? - Kawasaki ZX-10R.net
 2Likes
post #1 of 15 Old 03-22-2014, 09:51 PM Thread Starter
where do most racers relocate their regulator? mounted on stock plastics but wont work with race bodywork.
thinking i'll have to fabricate a bracket and mount to frame.
a pic would be greatly appreciated
seann137 is offline
post #2 of 15 Old 03-23-2014, 08:03 AM
kman0066's Avatar
I have mine mounted to one of the bolt holes left from removing the front sprocket cover. I was able to use the bracket from the fairing with an extra hole drilled in it for the mount. I tried using the small tabs that are already on the bracket, but they broke because of vibrations, so that is why I drilled a new hole in the bracket to mount it.
WERA Expert #43
2012 WERA National Challenge Series Open Superstock Novice Champion
http://maps.wera.com/racers/racerpro...30532136163864
COMET RACING LEATHERS
2011 ZX-10R Race bike (Vortex, Silkolene, Leatt, Yoshimura, BRIDGESTONE)
2013 ZX-6R 636 Race bike
2008 Ducati Hypermotard 1100s
kman0066 is offline
post #3 of 15 Old 03-23-2014, 09:07 AM
Blanco's Avatar
Nicely done Kman.
Sean, you may know this already since I saw your WTB ad for the kit oil catch tank, but it is designed to bolt the reg to it...
http://www.untamedvelocity.com/2011%...ke%20build.htm
Another benefit of the race kit oil catch tank is that it includes a new location for the voltage regulator, relocating it from the stock upper fairing mount to the left side of the engine. The only issue here is that one of the three-wire harnesses leading to the voltage regulator has to be lengthened in order to relocate the regulator; this harness leads to the black connector as shown in the left photo above. Note that the left (gray) connector has enough spare wiring to simply be re-routed to the new location.
After splicing the harness to the black connector and lengthening it approximately 12" using 10 gauge and 12 gauge wire (to match the OEM wires), it's time to prepare the mounting site. In the center photo above, the arrows show where the catch tank mounting brackets will be bolted and the circles point out two crankcase bolts with copper washers under them. Since copper washers are an indication there is fluid behind the bolt (oil), these need to be safety wired before being hidden away behind the catch tank. Mark the bolts and remove them, then drill the bolts with a 3/32" bit and re-install them with safety wire as shown.
Blanco is offline
post #4 of 15 Old 03-23-2014, 09:24 AM Thread Starter
awesome. thanks, kman. that will do it.
yea, blanco, that's one of the reasons i was looking for one but turns out that those little things are high dollar.
seann137 is offline
post #5 of 15 Old 05-01-2014, 02:14 PM
Near the shock, under the battery.
TomLSTD is offline
post #6 of 15 Old 05-04-2014, 08:52 PM
LDH
LDH's Avatar
After 2 days of thinking about this and weighing out the options of splicing more wire onto the harness to make it long enough to move it back to the sprocket area or even further I just said screw this stupid shit and decided to bolt the damn thing right to the inside pocket of the upper race fairing. Problem solved.
LDH is offline
post #7 of 15 Old 05-04-2014, 08:59 PM
Dark_3r's Avatar
^^^ thats where mine sits as well
Dark_3r is offline
post #8 of 15 Old 05-04-2014, 10:44 PM
Ahhhhh very nice! Way better than how I MacGuyver'ed mine haha.
ZX10RArcher is offline
post #9 of 15 Old 06-06-2014, 10:43 PM
What we did before getting the oil catch tank was drilled two holes in the sprocket cover worked a treat.
2014 Sponsors of Barker Racing
Pirelli
Spy Optics
AXO Leathers
Chicken Hawk Racing
Galfer Brakes and Lines
Kraus Racing
Sebimoto Fairing
If you would like to sponsor the fastest American racing in Germany please contact for details.
barkerracing59 is offline
post #10 of 15 Old 06-12-2014, 11:04 PM
Good post. Thanks for the pics...I'll be doing this soon.
cfarrell is offline
Gen 2: Rectifier Voltage Regulator* Zx10EBONYZx10 Wanted: Buy or Trade 2 12-23-2012 06:51 PM
Gen 3: Voltage Regulator/Recifier millwoodva Wanted: Buy or Trade 3 06-04-2012 08:27 AM
Recall on Voltage regulator Leone848 General Motorcycle Discussions 5 05-10-2012 06:21 PM
Gen 3: Voltage regulator recall. IggyBcool The ZX-10R 3 03-14-2012 07:26 AM
Gen 3: voltage regulator recall questions COVY The ZX-10R 2 03-11-2012 07:21 PM
