Q3 or Slicks - Kawasaki ZX-10R.net
post #1 of 13 Old 03-14-2014, 08:26 PM Thread Starter
Q3 or Slicks
This is my first post I would like to thank everyone for the information I have gained from the many posts I have read. I have a 08 zx10 that I am using for track days only. The suspension is stock at this point. I ran a day and a half due to rain at Mid-Ohio last Auguest on Q3's with 0 miles on them. The tires felt great even on a drying track. My first question is how many track days can I get out of a set of tires running at a intermediat pace. I am heading out to Barber first week of April should I bring anther set of tires if so would it be beneficial to go to slicks? Any imput is greatly appreciated. Cheers.4:
Jrocz2002 is offline
post #2 of 13 Old 03-14-2014, 09:27 PM
SkyDork's Avatar
If you're truly running at intermediate pace and depending on bike setup and track conditions, you'll be lucky to get 2 days out of a rear Q3. Slicks will likely be the same or a bit worse. Depending on the compound. And usually require tire warmers to get the most out of them. You'll be running faster on those though, all things considered.
#WordCrimes
SkyDork is offline
post #3 of 13 Old 03-14-2014, 10:52 PM
BusaCaptain's Avatar
I run slicks in advanced and I get 3 track days at best out of them and you do need warmers for them.
2008 Hayabusa-Yosh Full Race Exhaust can cut 5", PCV w/Autotune, BMC Filter, Cruise Control, HID's. Last Dyno Run 183 Rwhp/107 Ftlbs at 48,954 miles
2006 ZX10R-Street/Track bike- Only mods -1 Front Sprocket, Exhaust Baffle Kit.
2015 R1 (not stock) Imagine that
BusaCaptain is offline
post #4 of 13 Old 03-14-2014, 11:02 PM
TechX's Avatar
I can get 3 to 4 track days out of a Q3 rear. I usually go 2 rears to one front.
TechX is offline
post #5 of 13 Old 03-14-2014, 11:21 PM Thread Starter
Thank you. Let me go one step further I purchased warmers for this season and this will be my first trip using them sounds like I will need to replace at least my rear so in your opinion's should I go with slicks or stay with the Q3's. If I go with slicks what is the best to run?
post #6 of 13 Old 03-14-2014, 11:42 PM
TechX's Avatar
I really liked the Pirelli slicks SC2 good grip and feel. The rear would last only 2 track days and their freakin expensive like near four bills a set. You should be able to get the Q3s for under 300 a set.
TechX is offline
post #7 of 13 Old 03-15-2014, 12:10 AM
You'll get many opinions on who's are the best. It all comes down to personal preference. I've ran Bridgestone's and Dunlop's with good results on both. You have to run lower pressures with the Dunlop's.
post #8 of 13 Old 03-15-2014, 07:52 AM
dricked's Avatar
With Dunlop slicks, a rear I can get around 70 laps with flipping it and the fronts will last twice that easily. Go with a UK made front and US rear for cost effectiveness.
You could alway try a DOT race tire instead.
dricked is offline
post #9 of 13 Old 03-15-2014, 08:21 AM
TheLastViking's Avatar
2 and 3 days for a Q3??!!??
Check your tire pressures and or suspension. Something is WRONG with your bike.
I've put 4 race practice trackdays on a set, and a few races. Still got half life. Saving them for my street bike (restoring a 93 ZX7) now that I'm on 211s and slicks.
They'll last a damn long time if you take care of them. I can get more life out of Q3's than any other tire. I switched off because I was spinning the rear occasionally in races. Nothing worrisome, but I wanted to see if it could be eliminated with different tires. It can. Of course, better throttle control would work too.
You can hold a pretty blistering pace even on super shitty tires if you have a good throttle hand.
TheLastViking is offline
post #10 of 13 Old 03-15-2014, 08:51 AM
caboose's Avatar
Send a message via MSN to caboose
The front's last even longer than that. No one knows how long exactly..... I go through 6 US rears to 1 UK front and that's just because that's crazy... not because the tire is actually falling off.
70 laps out of a rear sounds about right (as longs as you're fast enough to keep it hot!)
2010 10R Superbike
caboose is offline
shinko slicks ? soxxerms Performance and Tech 7 10-18-2008 11:05 AM
Want to buy Slicks NachoZX10R Vendors deals 0 02-19-2008 12:01 PM
Gearing + Slicks. barnymb Track 8 05-05-2007 06:26 AM
Where to buy some slicks? ryanbz2001 Performance and Tech 15 04-03-2007 08:45 PM
Which slicks? chicken The ZX-10R 1 05-03-2004 09:21 AM
