Kit/Race ECU Launch Control impressions - Kawasaki ZX-10R.net
post #1 of 12 Old 03-04-2015, 01:02 PM Thread Starter
Looking for feedback from anyone whose used the launch control features of the kit ECU on the track / race grids.
Or perhaps there's other features like T/C tuning that's even better.
I do find the "race" mode for TC is still too intrusive.
As for Launch control:
Has it really helped you off the line?
Does it hold 1st gear RPM's to a certain RPM limit?
Does it feel like you have to shift into 2nd sooner then normal?
Just looking for actual racer impressions to see where I put this on my list of racebike upgrades.
TrackAddict28 is offline
post #2 of 12 Old 03-04-2015, 01:19 PM
fireman69's Avatar
I have quit using it because it just limits the RPM to a preset number. So if you set it to 8500, you need to be in 2nd by 8500 rpm or it will fall flat on it's face when you hit that pre set ceiling.
It works well for tracks that offer you the ability to hit 2nd before a turn, but if you have a long straight before corner 1 it just doesn't seem to work well, for me at least
fireman69 is offline
post #3 of 12 Old 03-04-2015, 01:52 PM
Here is what the kit ECU launch control config looks like. Particularly items 11 and 12.
Name:	Screenshot 2015-03-04 13.43.09.jpg
Here is what Woolich's launch control (default values) look like.
Haven't had a chance to test out either, hoping to test out the Woolich here next week as it looks like we're supposed to finally hit spring with 40s, 50s and 60s
From what I've been told by the guys I've flashed and put the launch control in for them, they love it.
I think the Woolich stuff may be the superior option here simply because you get a little more adjustability over the kit stuff. Just my two pennies. Again that opinion is just based off of going through the kit software and playing with that and the Woolich stuff. I won't have a definitive answer till next week when I should be able to try out both systems.
ZX10RArcher is offline
post #4 of 12 Old 03-04-2015, 02:02 PM Thread Starter
Yep I've heard that a couple times. Forgetting to grab 2nd gear quick enough kills your starting momentum.
Did you play with setting the upper RPM limit higher to 11K or similar?
post #5 of 12 Old 03-04-2015, 02:05 PM Thread Starter
Thanks for the screenprint there.
Will stay tuned after you do some testing.
Don't know much about the Woolich system. Will looking that.
post #6 of 12 Old 03-04-2015, 02:16 PM
fireman69's Avatar
I tried 9500 rpm but that made the launch less predictable. It looked alot like this
post #7 of 12 Old 03-04-2015, 02:18 PM Thread Starter
Ha funny.
Kinda defeats the purpose of L/C then.
I can already do that....and often do :)
post #8 of 12 Old 03-04-2015, 02:21 PM
dricked's Avatar
The kit launch controll f'd up every start I did last season. In the last race I got the holeshot and then 8000rpm happened and I was back to 5th. I'm lucky I didn't get asspacked.
I found I was getting a good launch at ~7500rpm, right where the motor starts to smooth out.
dricked is offline
post #9 of 12 Old 03-04-2015, 02:47 PM
Usually setting the launch control slightly before where the motor makes peak torque is where you want to set values for launch control. Set it at peak torque and you get more acceleration up rather than out. Set it a little before, and you'll have enough torque to drive out and not bring the front up too much.
So saying you were getting better, consistent launches at ~7500 RPMs make sense.
Again this is for people that are lighter. Heavier guys or track conditions will warrant adjusting the launch RPM some.
post #10 of 12 Old 03-04-2015, 04:09 PM
dricked's Avatar
Sorry I should have clarified, I didn't even try and use the LC. I had it turned on in the settings but didn't do the activation procedure, it just came on which is apparently normal. I won't be using it this year.
dricked is offline
Gen 4: Race kit ECU Settings vs stock ECU abadassbikerlad The ZX-10R 1 03-15-2014 07:27 PM
Let me ask you this: drag racers would this launch control help you? URBAN LEGEND Pictures and Videos 8 09-06-2012 10:32 PM
launch control/kit ecu multisport Performance and Tech 14 07-21-2012 02:54 AM
Gen 4: Factory Kit Race Parts :Akrapovic. Kit Harness & ECU Bevan175 Parts, Gear and Accessories 0 06-28-2011 01:58 PM
2 step launch control Uwan Pictures and Videos 1 10-01-2008 06:51 PM
