Gen 4: 2011-2015 Gen 4 Racers: What is your Rear Wheel set at - Kawasaki ZX-10R.net
post #1 of 17 Old 02-25-2014, 05:25 PM Thread Starter
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
Smile Gen 4 Racers: What is your Rear Wheel set at
Im changing my street and race bike 2011 ZX10R chain and sprocket and on average I push my race bike wheel base back a few knotches but I was told by one Kaw rider that they leave it stock.
Do anyone push it back some to keep the front end down for races and trackdays?
CCS/ASRA Novice 325 | WERA Novice 325 | The Nightmare of Summit Point
2016 ZX10R ABS | 2011 ZX10R | 2019 KTM 250XC-F
GunnRunnaz.com|Gunn Runnaz on FaceBook
Vonstallin is offline
post #2 of 17 Old 02-25-2014, 05:27 PM
Zr1
Zr1's Avatar
I keep mine far back as possible but with my gearing changing, sometimes I have to move the rear wheel forward a smidgen. Only time I wheelie (bad) is on the starts. I've got to work on that!
CMRA #713
Zr1 is offline
post #3 of 17 Old 02-25-2014, 09:07 PM
Joel's Avatar
I had mine in really close, within the first 1/3, it turned awesome and was still pretty good under straight line power. In say that I've changed gearing again and now I'm 5mm closer in than standard and I can tell the difference, it turns in slightly slower.
Joel is offline
post #4 of 17 Old 02-25-2014, 10:26 PM
TurboR1's Avatar
Keep it in the middle, gives you the most movement forwards or rearwards to allow for gearing change.
Stability and geometry should remain the same as the blocks are angled, the further the wheel goes back, the higher the rear gets countering the longer wheelbase.
The only thing that may get affected is the leverage on the rear shock (greater loading on the shock from a longer lever due to the wheel being back). so you may require a touch more compression dampening if moving the wheel back.
TurboR1 is offline
post #5 of 17 Old 02-26-2014, 02:54 PM Thread Starter
Vonstallin's Avatar
Images: 16
Ah ok thanks....
currently I have it about 10mm further back towards the end.
I have -2f/+2R.
I'm about to buy a new chain and gearing possibly (-2F/+1R) and debating where to set it just in case I do not like that gear setting...
I normally push the wheel base way back, but the same fast racer who told me to go with the 2/2 set up in gearing also said stock wheelbase.
It seems like it would be a wheelie monster.
post #6 of 17 Old 02-26-2014, 02:56 PM
Zr1
Zr1's Avatar
Are you planning on making the CMRA / wera event at TWS?
CMRA #713
Zr1 is offline
post #7 of 17 Old 02-27-2014, 12:04 PM
I pulled mine back a bit from stock just yesterday with a 2/2 setup
zxfan is offline
post #8 of 17 Old 02-27-2014, 12:17 PM
Brad_the_noob's Avatar
Wow 2/2. Sounds like it would want to wheelie a lot. I'm -1,+2 and the front doesn't come up too much. I should try 2/2.
Brad_the_noob is offline
post #9 of 17 Old 03-03-2014, 04:58 PM
TurboR1's Avatar
2/2 does sound extreme. Unless there are some really tight 1 gear corners on the track.
The general tried and true method for ZX10R racers in Oz seems to favour -1/+2 (-1/+3) depending on track. This works well for Wanneroo Raceway in the West (only hitting 5th gear on the long straight) and also Phillip Island where the long straight simply means you get to use 6th.
I have been told before to avoid going more than -1 on the front as the size of the front sprocket is now starting to get quite small, forcing the chain to start making a more rapid change in direction, this starts to put extra strain/load on the chain which starts to take up horse power...
The fact behind that claim I have yet to witness first hand but if anyone wants to give it a shot on the dyno, compare a -2/+1, to a -1/+4 and post the results.
TurboR1 is offline
post #10 of 17 Old 05-01-2014, 02:14 PM
Depends on the track. For tighter tracks I have my wheel more forward. Most of the time, no matter the track, it's in the middle though just because that's where it feels more comfortable.
TomLSTD is offline
Gen 3: For Sale: Gen 3 2009 ZX10R Parts (Full Wheel Set!) motobman Parts, Gear and Accessories 18 08-01-2013 04:42 PM
rear set for gen 2 mrkidd Wanted: Buy or Trade 0 01-14-2013 10:20 PM
FS gen2 rear wheel and full set of rotors punishmentcycle Parts, Gear and Accessories 2 10-11-2012 03:52 PM
Gen 2 or 3 Carrozzeria Rear Wheel with Galfer rear and front rotors Killerzxrider Parts, Gear and Accessories 22 10-04-2012 08:36 AM
Wanted: Gen 1 rear set SILKIE SMOOTHE Wanted: Buy or Trade 5 11-19-2011 06:28 AM
