Gen 1 race prep question (AFM) - Kawasaki ZX-10R.net
post #1 of 5 Old 10-15-2015, 10:53 AM Thread Starter
rabbit's Avatar
I'm hoping someone who has raced a gen 1 can chime in. I've been trying to contact AFM tech with no response. Since my triple project isn't going to be ready for next season I'm going to race the 10.
My question is about the case covers. I've found NRC aluminum covers. Are these acceptable? They list three covers: LH starter outer, LH starter inner, and RH ignition. There is no RH clutch cover available. The "inner" LH starter cover is under the "outer" one and the OEM part has a rubber slider on it. Do I just need the left and right "outer" covers, or do I need the "inner" as well? Do I need to do anything with the OEM clutch cover?
Bonus question: did you guys run stock brakes? I swapped to zx-14 calipers years ago and can't imagine racing with the stockers. I'll race up in the open classes before I switch back.
Thanks in advance.
rabbit is offline
post #2 of 5 Old 10-15-2015, 11:51 AM
Always On Mod
Animal11's Avatar
Thanks in advance.
Hey, I race a G4 in AFM. For the case covers, as long as they are aftermarket aluminum protective covers you are following the rules. They allow the GB ones too, but not all composite covers. you don't have to worry about the RH clutch cover. For the LH side I'd guess you just need the outer, but hard to tell without pics.
I run stock brakes so I can race Open Prod. That's the only class that requires stock parts. Open GP, Open SB, Formula Pacific, or Clubman HVY if you're a novice, all allow upgrades to the brakes.
I race a 450 also, so feel free to ask any questions there I may be able to help.
Hope to see you at Buttonwillow.
Fast parts, Great Service: PM Mike at Rider's Discount
Animal11 is offline
post #3 of 5 Old 10-15-2015, 12:08 PM
TechX's Avatar
Its hard to find covers for the gen 1 these days I have the NRC cover's on my gen 1. I did the Nissin calipers from an 08 ZX6 and then swapped those for Brembo's.
TechX is offline
post #4 of 5 Old 10-15-2015, 04:06 PM Thread Starter
rabbit's Avatar
Thanks for the replies. I'm not sure why they make an inner and outer for the left. The inner is a lot more expensive and requires a lot more work to install, but I didn't want to show up at tech with just an outer and fail.
Because of the brakes I'll probably end up in Open SB. Doesn't really matter. With me in the seat I could put the tenner up against the ninjettes and get smoked. I won't be running until spring anyway. Too much going on and I've scrapped my plans for this year.
rabbit is offline
post #5 of 5 Old 10-15-2015, 09:16 PM
bluedevil's Avatar
I have a WoodCraft(i believe) for left side talking about the big cover starter clutch cover very solid I may sell for the right price....I was going to practice with it on my powerdercoat gun and install on my project Gen 1...maybe.....but if I get a good offer I will be willing to sell just let me know if your interested in it.
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
Gen 4: 2012 zx10 track prep question jmhamilton68 The ZX-10R 22 09-09-2015 02:28 PM
09 - 6R Race Prep millwoodva ZX-6R & ZX-6RR Archives 53 10-04-2009 07:21 AM
race prep (fuel tank vent) edgeflyer Race and Stunt 1 08-10-2009 08:58 AM
Almost AFM Race Ready!!!!!! ducatiryder89 Race and Stunt 28 09-27-2008 09:24 PM
Track Prep Question.... Fuses Hoser Track 4 05-02-2007 11:01 PM
