anyone ever used a bazzaz shift sensor with the Kit ecu? - Kawasaki ZX-10R.net
post #1 of 9 Old 01-28-2015, 02:50 PM Thread Starter
as the title says, if so, how did you wire it up?
J_fuggin_t is offline
post #2 of 9 Old 05-31-2017, 11:27 PM
reviving an old thread... I was wanting to know the same thing... and judging by no replies since 2015..... probably no?
JB751 is offline
post #3 of 9 Old 06-01-2017, 03:37 AM
it was easier to buy and use a Dynojet quickshift sensor.
JayBoCC2 is offline
post #4 of 9 Old 06-01-2017, 04:22 AM
Carlos76's Avatar
Gen4 kit ECU needs switch type sensor, power is cut when two wires make contact. I belive most sensors act like this.
A member here used Panigale oem sensor (pull type,makes reverse pattern for Gen4). I did grab one from eBay and needed to make custom rod, since it has M8 thread. Looks ugly and works very good.
Gen4 race: high spec.
Suzuki GSX1300R Hayabusa 2013: stock.
Kawasaki KX450F 2016: love it.
Carlos76 is offline
post #5 of 9 Old 06-01-2017, 08:33 AM
mpp12's Avatar
bazzaz uses a bazzaz only sensor, that uses 3 cables....
mpp12 is offline
post #6 of 9 Old 06-01-2017, 10:21 AM
theatiss's Avatar
I have used with my gen3 race ecu a lot of shifter sensors like dynojet , pk power even a simpl kick starter valve from a r1. u could easily use any sensor that cut power when the contact done.
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #7 of 9 Old 06-01-2017, 03:57 PM
I used a panigale 1199 oem quickshift sensor on my Gen 1 with a PC3. I bought the PC3 plug end, and clipped a ducati connector off my friends discarded tail and have it grafted together quiet nicely.
That said my Gen4 trackbike uses a dynojet QS sensor with my Kit ECU and Harness. The Kit ecu has a provision for the dynojet connector so thats why it was used.
You can zoom in and see the quickshifter on my Gen1 here: https://scontent.xx.fbcdn.net/v/t31....e7&oe=599FEACB
JayBoCC2 is offline
post #8 of 9 Old 06-01-2017, 04:51 PM
thanks for all the replies! i will just snag a dynojet sensor. Had a lead on a bazzaz sensor cheap, but dynojet it is!
JB751 is offline
post #9 of 9 Old 06-02-2017, 08:42 AM
swopesy's Avatar
If we're talking the older style bazzaz sensor (push vs pull), the third wire is just for the sensor light. I see no reason you couldn't use a bazzaz sensor with the kit ecu by just using the two leads. With that said, I tore an old, broken sensor apart and the wires were very small gauge and pretty hard to work with and hard to get to with the casing they use.-Steven
Sent from my HTC Desire 625 using Tapatalk
swopesy is offline
G4 Kit ecu DJ sensor? dricked Performance and Tech 2 05-06-2014 08:22 AM
Trade: WTT: Bazzaz shift sensor. Push for pull. Cocky Rooster Parts, Gear and Accessories 4 06-07-2012 01:15 PM
08-10 Kawasaki zx10r Bazzaz ZFI QS complete with harnesses and pull sensor ( GP shift anthonyzx10r2008 The ZX-10R 10 02-23-2012 07:16 PM
Gen3: Throttle position sensor, and Crank sensor, where are they? (bazzaz related) Dr.Duct_Mossburg The ZX-10R 2 05-15-2011 07:16 PM
Bazzaz Performance Shift Light Kit for QS4 USB ridersdiscount Riders Discount 0 10-26-2010 01:11 PM
