2019 track bike - Kawasaki ZX-10R.net
 10Likes
post #1 of 20 Old 04-03-2019, 08:17 AM Thread Starter
2019 track bike
I'm in the midst of prepping my 2019 ZX-10R for the race track. I have the stock body work removed and do not yet have the race plastic (it's on the way from Peru).
One issue I'm trying to get in front of is all the the electronics on the left side of the bike. There is a fuse box and the regulator as well as other things packed in there. It was all fastened to the stock body and now that the stock body is gone, I dont know how I'm going to mount it all.
The question I have is, what have others done to deal with this stuff?
Sent from my SM-G935R4 using Tapatalk
Bloose is offline
post #2 of 20 Old 04-03-2019, 08:52 AM
On my 18' I zip tied all the wires has tight and neat as possible and kept rectifier in same spot and drilled 1 hole in track plastics to put one bolt through body and rectifier in similar location as stock. I have more than enough clearance between all that mess and fork tubes. Others will chime in with probably cleaner ways to do so but I haven't had an issue yet.
What other mods have you got planned?
wheelz96 is offline
post #3 of 20 Old 04-03-2019, 11:30 AM Thread Starter
Not too many mods planned just yet.
Obviously race body
Woolich tuner and logger
Wide band O2
K&N filter
Decat
Slip on
Removed intake flap
520 chain and sprockets and lower ratio
Dyno time
DP race pads
Keyless fuel cap
Ignition key delete
Going to run the stock suspension and will only change spring rates if needed. Stock brakes and wheels too.
wheelz96 likes this.
Bloose is offline
post #4 of 20 Old 04-03-2019, 12:44 PM
Obviously race body
Wide band O2
K&N filter
Decat
Slip on
Removed intake flap
Dyno time
DP race pads
Keyless fuel cap
Ignition key delete
Yea you will be happy with the bike! I am running a very similar setup only with spring change but still stock suspension setup for me. Sprocket change and de-restricting ECU will be best upgrades! I just upgraded brake fluid and put on RJL pads and one finger braking power all day long..
What tracks will you be running?
wheelz96 is offline
post #5 of 20 Old 04-03-2019, 01:48 PM Thread Starter
Racing CCS Midwest. Thatís mostly Blackhawk Farms but also a day at ACC and one at Brainerd. Will also be running Road America and likely a weekend at Barber to break the motor in.
YSR50 and JUICEBOX like this.
Bloose is offline
post #6 of 20 Old 04-03-2019, 05:03 PM
Kit Harness/ECU will clean all that excess wiring stuff very nicely.
Lanister is offline
post #7 of 20 Old 04-03-2019, 08:05 PM Thread Starter
I'm too cheap for such things
Bloose is offline
post #8 of 20 Old 04-03-2019, 09:04 PM Thread Starter
Has anyone eliminated the key switch on these yet? I tried to install a push button and a relay but there is a gray wire from the key switch to the ECU. I don't have the immobilizer but it seems this grey wire has something other than a full 12vdc. When I turn the key to the on position I read 100 ohm between the grey and white wires. I'm not sure if its straight resistance or if there is some circuitry in there.
Bloose is offline
post #9 of 20 Old 04-05-2019, 11:36 AM Thread Starter
Thanks to a post I found on a different generation ZX10R I was able to determine that the grey wire is indeed just 12vdc with a 100 ohm resistor in line going to the ECU. Connected that up and I no longer need a key!
Made a plate to press into the old switch hole. Hopefully it will stay put.
or10r likes this.
Bloose is offline
post #10 of 20 Old 04-05-2019, 11:37 AM Thread Starter
Powered up
bbsteinnewyork likes this.
Bloose is offline
decisions, decisions.. 2019 zx10r or 2019 s1000rr tukn20s General Motorcycle Discussions 57 03-26-2019 03:28 AM
2019 Kawasaki Ninja ZX-10R Receives Engine Updates, Now Claims 200hp YSR50 News 11 11-19-2018 05:50 AM
Sykes and Kawasaki to part ways for 2019 YSR50 News 42 11-04-2018 11:14 PM
2019 Kawasaki Ninja ZX-6R Preview YSR50 News 10 10-12-2018 01:08 PM
Gen 6 2019 ZX10R Coming !!! Vonstallin The ZX-10R 93 09-18-2018 03:08 PM
