Gen 1: 2004-2005 Yeah.. So... Im here now, too.... - Kawasaki ZX-10R.net
 1Likes
post #1 of 15 Old 04-04-2015, 10:21 PM Thread Starter
Howdy, all....
Some of you may know me from BARF, ADVRider, etc....
I traded an old race bike of mine that had been in storage for an 04 ZX10R, (that had also been warehoused for 8 years :D).
I'll be lurking around, looking into doing stuff while I have it apart for inspection and such. I know I need to change the front master, it needs some head bearing love as well.
I had heard that the forks can be questionable on this thing. If there is any information I could be pointed to on that, it would be great... And, hell, any other information for stuff to look out for/change would be hella awesome!
Cheers!
-Jake
Jakemate is offline
post #2 of 15 Old 04-05-2015, 07:23 PM
blink.'s Avatar
Welcome! I would check the underside of the frame for cracks.
Any pics?
blink. is offline
post #3 of 15 Old 04-08-2015, 08:34 PM Thread Starter
Yeah... I'll upload some to a host in a bit...
Jakemate is offline
post #4 of 15 Old 04-08-2015, 08:52 PM
Jake's Avatar
Welcome other Jake!
Jake is offline
post #5 of 15 Old 04-08-2015, 10:15 PM
keithk's Avatar
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #6 of 15 Old 04-09-2015, 12:18 PM
Arnbo's Avatar
Welcome and I second looking for cracks in the frame.
Had a friend find out his frame was cracked on a ride when someone
mentioned and then showed him what and where to look. Gen1 Beast!!!
Arnbo is offline
post #7 of 15 Old 04-09-2015, 10:48 PM
Welcome!
pacmanzx is offline
post #8 of 15 Old 04-10-2015, 08:14 AM
Johns04ZX10R's Avatar
Frame cracks are common on 1st gen. Also a good idea to pull out the generator and replace the thrust washers with the updated version.
Fork seals usually leak on any Kawasaki with the black for tubes. Probably a good idea to change the fork oil and clean out the internals anyway. 1st gen forks are very easy to service.
Leave the secondaries in the TB, but disconnect the exhaust valve (if you have stock header).
-1+2 gearing for serious attitude adjustment
and of course -- dump the gas, install new spark plugs, and sync the TB's.
WELCOME TO GEN 1 NIRVANA!!
A 1st Gen Ten will eat the hearts of grown men.
Johns04ZX10R is offline
post #9 of 15 Old 04-12-2015, 11:49 AM Thread Starter
It has a cored out pipe, and a remapped ecu.... I'll be servicing about everything.
I pulled the plugs, fog oiled the cyls, changed the filters, changed the oil. Cranked it by hand. Blew the oil out of the cyls. Dumped the gas, replaced with high test treated with sea foam and inj cleaner. Changed the battery to a shorai....
Sounds pretty nice....
ID:	318753   Click image for larger version
ID:	318761   Click image for larger version
Jakemate is offline
post #10 of 15 Old 04-12-2015, 11:55 AM Thread Starter
So... Where are the common cracks, or am I spraying every weld with penetrant to check everything? Also, what grade aluminum is the frame, in case I need to disassemble to reweld....
Jakemate is offline
Gen 3: Oh yeah FluxFreak13 Welcome Newbies! 2 06-13-2011 09:27 AM
yeah right? badexample Pictures and Videos 11 09-15-2010 10:20 AM
Oh, yeah? gpz1100 The Out House 10 11-09-2007 03:32 PM
yeah yeah got me a new bike. sabersaw30 Pictures and Videos 7 07-16-2006 11:50 AM
Oh yeah!!!!!! ninjamaster6-10 Pictures and Videos 5 01-18-2006 04:19 PM
