Gen 1: 2004-2005 Starting issue - Kawasaki ZX-10R.net
post #1 of 5 Old 05-21-2019, 02:43 PM Thread Starter
Starting issue
Hey guys was hoping someone could help me get some answers. I pulled my 04 zx10r out of storage and fired it up. It was running and warming up then just quit. Not it only turns over and fires up for about a half a second. I thought it might be a fuel pump so I replaced it with a new one still the same issue. No codes popping up and there is not F1 light coming on either. Any ideas would be much appreciated thanks.
KalvinB is offline
post #2 of 5 Old 05-21-2019, 03:29 PM
michael4012's Avatar
how long was it running for and can you remember the temperature it got to before cutting out?
michael4012 is offline
post #3 of 5 Old 05-21-2019, 05:00 PM Thread Starter
Hey, I would say it was running for about a minute to a minute and a half wasn’t even warm enough for the temp to register on the cluster.
KalvinB is offline
post #4 of 5 Old 05-21-2019, 10:33 PM
I wonder if it cut out when it came off the automatic choke? Does it start if you give it a little and hold it throttle?
post #5 of 5 Old 05-22-2019, 01:55 PM Thread Starter
I tried cracking the throttle as well as having the throttle fully open and it just turned over and fired for about half a second.
KalvinB is offline
Rear tire slippage - tire issue? Suspension issue? Rider issue? silversixspeed Suspension and Tire Tech 41 10-25-2014 01:00 AM
2005 10r cold starting issue Tristkm The ZX-10R 5 01-09-2011 06:04 PM
Starting Issue with 07 zx10 Mikee The ZX-10R 11 08-06-2010 08:38 PM
Starting issue solved! CBRE Performance and Tech 2 09-09-2006 04:42 PM
Anyone else have a starting issue??? Rock_Star The ZX-10R 23 05-30-2006 08:48 AM
