Gen 2: 2006-2007 Odometer / speedometer - Kawasaki ZX-10R.net
post #1 of 4 Old 09-20-2018, 07:01 PM Thread Starter
Question Odometer / speedometer
Hi guys,
Brand new to the site, and fairly new to riding again after not having a bike for so long. Currently loving my 2006 ZX10R but noticed the distance being tracked on my odometer is further than that tracked by our family vehicles. Speeds display faster than actual as well. Example: 80 kmh when vehicle ahead is doing 70. I checked tire sizes and seem to be ok. Would anyone else have an opinion on what else could cause this?
While i appreciate any and all input, I'm quite out of my league when speaking mechanically.
NBGary is offline
post #2 of 4 Old 09-20-2018, 11:47 PM
michael4012's Avatar
What size sprockets are on the bike, it should be 17t (teeth) front & 41t rear.
michael4012 is offline
post #3 of 4 Old 09-21-2018, 02:33 AM
Melampus's Avatar
Arrow >> gearing <<
NBGARY <> As 4012, is alluding to, the gearing in your bike has most likely been altered by a sprocket(s) change. This is typically done by adding a larger rear or smaller front [sprocket] to increase acceleration rates. You can inspect your sprockets for a stamp that often states the amount of teeth. When this is done, it tricks your speedometer into thinking the bike is moving faster than it really is. There is a product known a SpeedoHealer that can correct this calculation.
Melampus is offline
post #4 of 4 Old 09-21-2018, 08:54 AM
SkyDork's Avatar
Yes, the older models get the speed reference off of the countershaft. It calculates the speed of the bike based on the engine speed. So if your final drive gearing is different than stock, the calculations are out-to-lunch. Rev the motor higher and the speed and mileage go up as a result. There is also a safety factor built into that and the speed will be higher than accurate than the mileage shows by about 8% or so. But if you're seeing higher mileage along with the speeds, then your gearing and/or tire size is different than stock. You'd need a Speedohealer type device connected to allow you to make changes to that as mentioned above.
#WordCrimes
SkyDork is offline
Speedometer/odometer problems on a 636... cecil_kawi Performance and Tech 1 11-13-2008 10:46 AM
Do larger/smaller sprocket affect the odometer? ExtendMy10R The ZX-10R 10 08-13-2008 10:29 AM
Anyone ever think of doing an odometer race? 06450F The ZX-10R 48 02-03-2007 01:56 PM
engine apart after 23,000 on the Odometer!!! PuertoRicoZX10 Performance and Tech 9 07-20-2006 11:18 PM
odometer reading justoyz2 The ZX-10R 7 10-31-2005 03:07 PM
