Newly Converted S1000RR Owner - Kawasaki ZX-10R.net
post #1 of 33 Old 08-30-2014, 08:23 PM Thread Starter
It's been a long road to get to this point, but I decided it was time for a change. I always had my eye on the ZX-10R, ever since I bought my S1000RR. I've had the BMW for about 2 years, and decided it was time for a switch. I just bought a new 13 ZX-10R today. I will be converting this bike into a race bike really soon. I'll have all my parts on order Tuesday because I have track day in 2 weeks and a race in 3. I'll list my planned mods below. Fell free to chime in on anything I may be forgetting.
-Akrapovic Slip-on and link pipe
-PCV w Autotune
-Dynojet quick shifter
-ECU reflash (haven't decided which one)
-K&N Race Filter
-Ohlins Steering Damper
-Ohlins Suspension
-Galfer steel braided brake lines
-R&G protection kit
-Woodcraft clip-ons
-520 conversion kit w DID ERV3 chain
-Vesrah Pads (either XX or 17, haven't decided yet)
-Brembo RCS19 master
-Sharkskinz bodywork
-Vortex rearsets
-Zero Gravity Corsa Windscreen (although I would like to know which screens they use in WSBK, they look like they provide more wind protection from being wider)
tonyugoh is offline
post #2 of 33 Old 08-30-2014, 11:11 PM
peterd10r's Avatar
Images: 7
Welcome bro hope you enjoy the 10R can I ask how did the beemer treat you??
peterd10r is offline
post #3 of 33 Old 08-30-2014, 11:16 PM
peterd10r's Avatar
Images: 7
Check out the guys on here with your flash man! ZXARCHER and ZXSILK not quite sure on the second name (sorry man) but if you do a search you will find very happy customers with both these guys mate
post #4 of 33 Old 08-30-2014, 11:19 PM
peterd10r's Avatar
Images: 7
ZX10-SIC R was the second guy cheers
post #5 of 33 Old 08-30-2014, 11:40 PM
STEALTH-FIGHTER's Avatar
-PCV w Autotune
-K&N Race Filter
-Ohlins Suspension
-R&G protection kit
-Woodcraft clip-ons
-Vortex rearsets
Welcome and congrats on the new 10R! I'm sure you will be Very happy with it.
As Peter said, Archer is the man for the reflash. Ton of options and Very affordable, especially compared to some others. Customer service and turn around are top notch. Check his threads out. He's constantly researching/testing and trying new stuff with the 10R. I haven't heard of the other guy mentioned, myself.
The steering damper should be electronic on yours correct? I have heard they were pretty well sorted by that year model. I have the '11 standard damper and had to send it out to be re-valved. Not bad as it costs $75 to upgrade and it performs on par with $400+ aftermarket options.
The windscreen I think is a preference thing. I don't think all WSBK have the same ones. Could be wrong though. A lot of people get the double bubble, but I can't stand the looks of it on this bike, and it seems to me that it would inevitably cause more drag. The Corsca I've owned and used for a while. It's ok. Not quite as vertical as the DB but it's taller than the standard (good for larger/taller riders that have a harder time fully tucking in. I prefer the standard personally. Think it looks the best and seems that it would have the least amount of drag, though that is just me speculating. There is also the new Marc 1. Basically the standard with a cut out up top, though sets more vertical than swept back via 1/4" spacers used between the screen and the body. Had that one too, though I just sold it.
Anyway, it looks like you have a good start on your upgrade list. Should be sweet when she's all set up!
What is best in life?..
TO CRUSH YOUR ENEMIES, TO SEE THEM DRIVEN BEFORE YOU, AND TO HEAR THE LAMENTATIONS OF THEIR WOMEN.
STEALTH-FIGHTER is offline
post #6 of 33 Old 08-31-2014, 07:59 AM Thread Starter
The BMW was great. The reason I choose that over the ZX-10R originally was because I felt like it fit me better. (I was 6'5" 310 lbs when I bought it) The things that I disliked about the S1000RR:
-Parts were really expensive
-Short gearing (I have to shorten my gearing to keep up with the smaller guys on the track, and that always kills my top end)
-The pogo effect on the TC
Other then that it was a great bike and treated me really well. I only rode it on the track, so I don't have any street knowledge of the bike.
I have been searching for exhaust and reflashes. I haven't decided who to go with yet.
tonyugoh is offline
post #7 of 33 Old 08-31-2014, 08:12 AM Thread Starter
Thanks. I looked at the DB screen, but thought I would get more protection from the Corsa since I am a bigger rider. The steering damper is electronic, and I heard your couldn't re-valve those. So I will have to get another one. I like GPR but thought I would try out the linear Ohlins damper on this bike.
tonyugoh is offline
post #8 of 33 Old 08-31-2014, 08:30 AM
Yeah the Corsa should give you plenty of protection, and will still look good with the lines on the bike. It worked very well for me (6'2"), I just prefered the SD aesthetically.
So the stock E. damper isn't that affective then? I know Kawi made them basically useless in the earlier models for liability reasons. Guess they're sticking with that line of thinking.
post #9 of 33 Old 08-31-2014, 08:57 AM
dricked's Avatar
If your going to ride track only get the kit ecu and wiring harness. It gives you the option to adjust the TC (it needs it!), you don't need a reflash, and it opens up a few more options on the bike. You can build your own com cable for less than $50 (google will bring it up). Also a rear shock linkage will be another big item to add. Depending on your pace the calipers may give you some brake fade after 4-5 laps. There's a few caliper options that are a direct swap for roughly $200.
dricked is offline
post #10 of 33 Old 08-31-2014, 10:52 AM
Slash24's Avatar
Welcome fellow Houstonian.
Slash24 is offline
Gen 1: Newly relocated zx10reaper Welcome Newbies! 0 04-14-2013 11:49 AM
previous gen 3 owner converted to gen 4 frankiebusa Welcome Newbies! 1 07-08-2011 08:48 PM
converted my10r Pictures and Videos 5 03-06-2011 01:40 PM
09 R1 Owner makes the ass end of the 09 look like the face of the BMW S1000RR!!! MagicMavis The Out House 8 04-06-2010 04:43 PM
Converted Exhaust skeet609 The ZX-10R 14 05-10-2007 12:12 AM
