Gen 5: 2016- Kawasaki zx-10r headlamp - Kawasaki ZX-10R.net
post #1 of 7 Old 02-02-2019, 10:24 AM Thread Starter
help, removed the headlamp, after removing the headlamp, I found a rubber tube, I canít find its place now, if you know help
Name:	viber image.jpg
ID:	420891   Click image for larger version
Name:	viber image1.jpg
Sasha12345678 is offline
post #2 of 7 Old 02-02-2019, 10:25 PM
ddipaola's Avatar
Originally Posted by Sasha12345678 View Post
help, removed the headlamp, after removing the headlamp, I found a rubber tube, I can’t find its place now, if you know help
That goes to an actuator for the charcoal canister. That entire canister can be removed, so no big deal. Search "emissions removal" or similar and you should find some tutorials with pics on here to help you figure things out if you're still lost.
When in doubt... send it!
ddipaola is offline
post #3 of 7 Old 02-03-2019, 05:23 AM Thread Starter
Thank you very much
post #4 of 7 Old 02-03-2019, 09:13 AM
Will this require a flash to clear the code when this is disconnected?
bbsteinnewyork is offline
post #5 of 7 Old 02-04-2019, 08:59 AM
ddipaola's Avatar
I don't believe so. Just unplug actuator thing and see if it throws a code. If it doesn't you're good to go.
Looks like it's that blue plug below the canister you want to unplug and see.
ddipaola is offline
post #6 of 7 Old 02-10-2019, 09:23 AM
So it does cause a code. I plugged it back In and cleared the code.
post #7 of 7 Old 02-10-2019, 02:10 PM
ddipaola's Avatar
Gonna have to flash it out then if you want to remove the whole thing.
ddipaola is offline
intermittent headlamp failure??? danno46 The ZX-10R 16 05-15-2011 05:37 PM
wtb broken headlamp for 2nd gen. dirt ninja Wanted: Buy or Trade 0 07-21-2009 08:08 AM
Headlamp limitations? TRAIL BOSS Performance and Tech 1 08-13-2008 06:56 AM
04/05 headlamp cord assy (21150) Racer-X Parts, Gear and Accessories 0 05-02-2008 10:04 AM
WTB/borrow: 06/07 headlamp-product development Fixer Wanted: Buy or Trade 0 07-06-2007 02:38 PM
