Kawasaki error - Kawasaki ZX-10R.net
post #1 of 4 Old 10-29-2016, 12:19 PM Thread Starter
Kawasaki error
Help!! Bought a Kawasaki ZX10R 2016, put a power commander on it and flushed the ECU. Every time it hits the rev limiter error codes appear on the dash.I took it to the dealer, they say the fault is on injector 6 and 7. They reset it but again when it hits the rev limiter the errors appear. Can someone maybe help?
KOOS is offline
post #2 of 4 Old 10-29-2016, 01:51 PM
belkins's Avatar
may want to double check your power commander connections. and by check i mean unplug and plug back every connection. If all is good with connections.. I would remove the power commander and flash back to stock and see if it happens. Gotta troubleshoot it and narrow it down. Did this start after the flashing of the ecu and or installing the power commander?
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #3 of 4 Old 10-30-2016, 12:13 PM Thread Starter
I flashed the ECU and put the power commander in at the same time.
KOOS is offline
post #4 of 4 Old 10-30-2016, 04:22 PM
The Pace
scout's Avatar
Just make it oem put a good can on and dump the fender. All it needs.
scout is offline
Gen 2: Error code 23? ZiG 9th The ZX-10R 16 01-07-2016 12:17 AM
Gen 4: Exhaust error Haga46 The ZX-10R 6 05-23-2014 08:32 AM
How Much Error?? Stwcar The ZX-10R 11 05-08-2009 05:32 PM
error 62 fbmbks Performance and Tech 16 05-08-2008 12:34 PM
