Gen 5: 2016- Installed PCV and won't stay running - Kawasaki ZX-10R.net
post #1 of 1 Old 08-05-2018, 04:55 PM Thread Starter
Exclamation Installed PCV and won't stay running
So, I installed my Poer Commander V on my 2016 zx10r, and ran into a peculiar issue. It only receives power while the fuel pump is pressurizing. I've checked the connections, and the ground. I can start the bike, and it runs, but as soon as it's pressurized, the PCV loses power, and the engine stops. One thing I should mention is that I didn't have the posi-tap connector. So, I went with a butt connector splicing the connection at the ecu connector on the purple wire connecting to pin #24, where you're supposed to posi-tap it. Could this be the problem, or could I have just gotten a junk PCV? Maybe a fuse is gone?
Dc84 is offline
Tags
power commander 5
HELP!! bike won't stay running Brodfard Tadd General Motorcycle Discussions 4 05-14-2017 01:12 PM
HELP!! bike won't stay running Brodfard Tadd The ZX-10R 8 03-11-2017 10:10 PM
Gen 1: Gen 1 won't stay in neutral rwarner56 The ZX-10R 10 06-25-2013 11:54 PM
Help bike won't stay running zacreeves Performance and Tech 5 05-26-2008 08:20 PM
Idle won't stay constant. 1killer1liter Performance and Tech 18 06-20-2006 10:42 AM
