How can I bypass the Tip / Vehicle Down Sensor - Kawasaki ZX-10R.net
post #1 of 2 Old 05-03-2010, 12:55 AM Thread Starter
I wrecked my bike last weekend and need to fire the engine up for potential buyers. I found that the tip sensor had been pulled out and destroyed(all the innards are missing). I searched but cannot find how to bypass the sensor. I do not want to pay or wait for a new one because the bike cant ride as it is anyways(brake lever broken, reservoir destroyed) I just need it to start to prove the engine is ok.
The wiring is BR/BK-Ground, Y/G- Output, BL-Power. Im thinking I can simply splice the the power into the output? Or will I need some sort of resistor?
imdrax is offline
post #2 of 2 Old 05-03-2010, 07:35 AM
TENN10's Avatar
Images: 145
What year model?
I haven't looking into bypassing a TOS, but it cant be hard to do. I'm assuming the wieght inside the sensor either opens or more likely closes a set of contacts. If so, yes, you can jump the power source to the output wire. You will need to see what signal the ECU is looking for. + or -
Do you have the service manual?
TENN10 is offline
Tip over sensor Jingalls1000 The ZX-10R 2 05-10-2009 07:19 PM
tip sensor? mgm112103 Performance and Tech 5 03-24-2009 03:52 PM
TIP OVER sensor? Ninja187 Performance and Tech 8 06-26-2008 11:20 PM
Tip Over Sensor ( Vehicle Down Sensor) Papo-T Performance and Tech 1 06-02-2008 07:12 AM
Wtd: Vehicle Down (tip over) sensor RussMcB Wanted: Buy or Trade 7 06-04-2007 09:46 AM
