Gen 1: 2004-2005 Hi there - Kawasaki ZX-10R.net
post #1 of 4 Old 06-25-2018, 05:02 PM Thread Starter
Hi there
Looking into getting a used 1st Gen for trackbike... Iím here for info on what to look for.
ariskardas is offline
post #2 of 4 Old 06-25-2018, 09:30 PM
Judge Dredd Mod
mr_honez's Avatar
BURNOUT.....
mr_honez is offline
post #3 of 4 Old 06-25-2018, 11:31 PM
michael4012's Avatar
Your in the right place for information on the G1 .....
michael4012 is offline
post #4 of 4 Old 06-26-2018, 02:24 AM Thread Starter
So after reading some around I think Im getting the gist of it.
Seems like beyond obvious abuse cases the most common issues are:
- 04 frame cracking/recall
- Oil leaks and coolant leaks from the engine block (some worst than others)
- Stator coil ďexplodingĒ (iím guessing the same denso magnet issue?)
Am I missing a lot? What would you guys add to the list to watch for about a used G1?
Also I read that the gearbox is a bit sensitive especially and the gears wear out more than normal? Is that true?
If i remember correctly this model had some sort of a slipper clutch? Is that true? And does it work well?
