Gen 1: 2004-2005 Help 2004 - Kawasaki ZX-10R.net
post #1 of 2 Old 02-28-2019, 06:59 PM Thread Starter
Help 2004
I need help ....diagnostics
I have what I believe is an or motor, harness and speedo assembly. I custom built a drag frame around the motor, and after a few months I finally got it running, but I shut it off and now it will not restart just cranks. I am not using a stock fuel tank or pump I have a 1 gal. Jaz fuel cell with an aftermarket high pressure pump which I have regulated back to 45-47 psi. And it would start and run a few dozen times even rode down the street and back no problem.. I do have a pingle cord style kill switch (which I have tested to work), the ignition switch bypass, and the lean over or bike drop bypass. And I am at my whits end. Is there any way to hook a scanner to these like with a vehicle. I do have a factory service manual but it is really vague about it and is more of a trouble shooting manual. Any help with this would be great thanks
Grady is offline
post #2 of 2 Old 02-28-2019, 11:36 PM
michael4012's Avatar
You would need the speedo cluster to pull codes from the stock ecu, which i presume you are using? I think you need too trace the fault the old fashioned way starting with spark & fuel?
michael4012 is offline
Gen 4: Help!!help!!help!! ChainBrain The ZX-10R 8 12-03-2014 09:44 AM
Help Help Help! 08ten The ZX-10R 12 03-11-2010 12:25 PM
Help Help Help Help 99vorsi Performance and Tech 15 02-25-2007 04:34 PM
2004 zx10r problem need help guyinhershey The ZX-10R 9 09-02-2005 05:32 PM
Need Help With Wiring or Wiring Diagram for 2004 ZX-10 cashes41 The ZX-10R 0 05-21-2004 03:24 PM
