Having trouble with Metzeler M3s - Kawasaki ZX-10R.net
post #1 of 1 Old 05-26-2010, 08:58 PM Thread Starter
Ninja_10R's Avatar
I have a 04 and a 09 zx10. Recently replaced the tires with Metzeler M3s. Previously, I had Diablo Rossos and BT016 on these bikes and they performed flawlessly. I used to run cold tire pressures - 36 psi front and 42 psi rear during summer months (in Australia). However, off late with the M3s, I have felt the rear slide when on the gas in corners. One of my buddies had a high side on these tires too. This has totally shattered my confidence in these tires. Now I run 34 psi front and 36 psi rear(cold tire pressures). After, this change the bike feels a bit unstable when the tires are cold, but it handles ok when the tires heat up. The edges of the tire however have a sort of blue/purple color. I understand this may be because of excessive heat. Can someone advice me whether I am running the right tire pressures. I generally ride pretty aggressive on the twisties and almost always scrape my foot pegs and toe sliders in the corners. I do not plan to buy these tires again, however still have a lot of tread left in them. So, can someone give me some useful tips in terms of what pressures to run them on. Thanks. *********I guess I posted this tread in the wrong section. have created a new tread. Please post replies at https://www.zx-10r.net/forum/showthre...43#post1459743
Thanks.
Ninja_10R is offline
Tags
metzeler sportec m3, tire pressure
Metzeler? sy360 General Motorcycle Discussions 8 06-08-2009 07:46 PM
metzler m3s busZX10R Performance and Tech 8 07-22-2007 09:31 PM
Metzler M3s and Pirelli Corsa IIIs Sinisterone Vendors deals 8 05-10-2007 10:15 PM
Metzeler RaceTec kawiiiiii Performance and Tech 10 02-08-2007 01:09 AM
Metzeler M3 [email protected] Vendors deals 8 08-08-2006 08:49 AM
