cant here fuel pump priming - Kawasaki ZX-10R.net
post #1 of 3 Old 01-17-2015, 09:46 AM Thread Starter
had a paint job on my zx10r 2008 and ever since it came back I cant start it it all turns over but I cant here fuel pump priming. I checked the wiring to the pump and all seems to be connected .
can any body help
reggiereg is offline
post #2 of 3 Old 01-17-2015, 09:57 AM
SkyDork's Avatar
can any body help
You can't HEAR the pump.
You need to see if power is getting to it. Pull the connector and put a meter on it to see if there's voltage there. If so, the pump is bad. In not, check the fuse and relay to see where the problem is.
#WordCrimes
SkyDork is offline
post #3 of 3 Old 01-19-2015, 12:01 PM Thread Starter
I checked power I have a permanent live when ignition on but no power to prim pump got a feeling could be relay .
So I got back in touch with the guy who did the paint job for me and he said to take it back for him to have a look and sort .
Thank you for your help
Removed tank, fuel pump trickling fuel constant neverendingmods Performance and Tech 9 07-21-2019 06:13 PM
2009 zx10r fuel tank with fuel pump $175 widowmaker81 Parts, Gear and Accessories 1 05-19-2014 08:47 PM
'05 Fuel pump not priming so wont start TrackAddict28 Performance and Tech 2 09-24-2009 01:40 AM
Oil Pump (that little pin, and priming a new engine) RussMcB Performance and Tech 7 08-05-2008 12:45 PM
Fuel pump gone...inline pump and regulator? bugman53 Performance and Tech 15 05-18-2008 10:39 AM
