Gen 2: 2006-2007 07’ coolant amount? - Kawasaki ZX-10R.net
post #1 of 3 Old 10-02-2018, 07:42 PM Thread Starter
Srusty's Avatar
07’ coolant amount?
Hi guys, I have just conducted a cooling system flush on my 07’. The manual says it should take 2.9Litres including the overflow but it seems to only want to take 2Litres.
I conducted the flush (vinegar & distilled water cleanse + distilled water flush) and bleed as the manual instructed including the draining through the water pump and the plug at the front of the cylinders.
Any ideas what I am missing?
I appreciate the help!
Srusty is offline
post #2 of 3 Old 10-03-2018, 10:14 AM
SkyDork's Avatar
If you've refilled and bled the air out of the system and the the fluid level shows between Min and Max on the reservoir, then you're done and it doesn't matter how much actual fluid it took. You don't measure coolant to the tenth of a litre or US gallon. If you see "2.9L" in the manual, then make sure you buy 3.0L of it to refill and you fill it up until it's full. That's it.
#WordCrimes
SkyDork is offline
post #3 of 3 Old 10-03-2018, 02:32 PM Thread Starter
Srusty's Avatar
Thanks for that mate. I hoping that was the case. Appreciate the help 🤙🏽
Srusty is offline
Gen 5: Different color Gen 5’s MPac The ZX-10R 96 08-20-2019 04:12 AM
Gen 2: 2007 Zx10r won’t start without jump [email protected] General Motorcycle Discussions 3 08-28-2018 05:17 PM
What is the average amount of miles you can get on 10 Burress8 The ZX-10R 16 03-28-2007 09:20 PM
Amount of Clutch play?? scalpelman Performance and Tech 2 07-23-2006 09:39 AM
Decreased amount of "headshake" mach_man_187 The ZX-10R 0 04-03-2005 03:35 PM
