Review of Greggs Fender Eliminators>>> - Kawasaki ZX-10R.net
post #1 of 2 Old 06-09-2005, 05:51 PM Thread Starter
Post Whore
El Diablo's Avatar
I finally bit the bullet and bought a set of Greggs Customs billet fender eliminator filler plates (without signals or tag bracket) so I thought I'd post up a review. Just got them in today and couldn't wait to fill those unsightly holes with these beautiful pieces! The fit seems perfect and the finish is excellent. The paint match looks good, although where they mount it would be all but impossible to see even a moderate mismatch. This just isn't a critical part for color match. I doubt people would ever notice if they were just gloss black with no metallic.
Anyway... The install is extremely simple. The hardest thing would be removing the factory fender and signal assembly and even that is as easy as two bolts, two nuts, and a few wiring connectors. With my fender/signals already removed all I had to do was find my loctite (time to buy another tube!), put the fillers into the holes in the undertail, loctite the included (size 3 allen head) screws and run them into the fillers from inside the trunk. Took maybe two minutes including fumbling around with the loctite.
The fillers pull the undertail back up snug against the trunk floor like the stock fender did, so that should put a stop to any flopping the tail section might have been doing before. They aren't quite flush mount, but they just barely sit higher than the holes in the tail. They blend in well with the tail and really clean it up compared to running with holes and no fillers.
I'm happy with the quality, fit, and finish of these fillers. The only thing I'd change is I'd like to have had a set without the tag bracket mounting holes, but I'm not sure that's even a possibility unless I had Gregg custom make a set without them. I'll find small black plugs for them or get some black headed screws and take care of those.
And now for the pics... I'll try to get better installed shots later. Gotta go take a nap now so I can work a side job tonight...
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #2 of 2 Old 06-09-2005, 05:52 PM Thread Starter
Post Whore
El Diablo's Avatar
Discuss this topic here...
https://zx-10r.net/forum/showthread.php?t=9317
El Diablo
I need a fender!!! Kawiman Parts, Gear and Accessories 0 03-28-2005 09:24 PM
Rear Fender Removal vgmaster The ZX-10R 3 03-21-2005 08:10 PM
Anyone have Greggs Custom eliminator? steves87 The ZX-10R 9 01-21-2005 11:46 PM
Competition Werkes Fender Eliminator Xusia The ZX-10R 29 07-18-2004 06:51 PM
Fender Eliminators moose The ZX-10R 20 05-11-2004 07:15 PM
You may not post replies
