Replacing Flasher Relay - Kawasaki ZX-10R.net
post #1 of 20 Old 04-04-2005, 10:13 AM Thread Starter
1rocket69's Avatar
Location: Used to be Candler, NC/ Then HELL in Del Rio, Tx/ Now Blaine, WA
Since many folks have had fast turn signal flasher problems after replacing the stock signals I thought we needed a How-To in this forum. Maybe this will help the ones that don't know this easy fix; Here goes
First you will need to go to your local parts store (ie.autozone, napa or whatever is near you), pick up a EL12 flasher relay and some crimp-on connectors(female type, I used 14-16 gauge, 18-20 will also work)
As far as tools you will only need a 10mm socket, 4mm allen socket, ratchet and extension, a pair of electrical crimping pliers and some electrial tape.
Take your rear seat or cowl off, then remove the small plastic piece behind the seat, it's held by two 4mm allen screws, just lift up it slides out from under the seat.
Next remove the one bolt holding your seat on, it's a 10mm, the seat just lifts off.
The flasher relay is in the back of the area, it's a small black box with a rubber strap like thing on it
ID:	2893   Click image for larger version
ID:	2895   Click image for larger version
ID:	2896   Click image for larger version
ID:	2897   Click image for larger version
Liberal-- A person who is so open minded that their brains have fallen out.
1rocket69 is offline
post #2 of 20 Old 04-04-2005, 01:10 PM Thread Starter
1rocket69's Avatar
Part 2
It would only let me load 5 pictures so here's the rest
Remove the old flasher relay and take out your wire cutters, clip both wires to the plug
Strip about 1/8" off of the wires and crimp your new connecters on,
your almost done
The new flasher has a X marked by the post for the positive side,on top it will say "must fuse X lead"
(this you plug the Brown/Yellow wire onto) it's the hot or + wire, comes from the fuse box
The other post has a L by it, this post you plug the orange wire onto, it's the - or negative, comes from the clip-on turn signal switch
I took the rubber clip thing off the old relay and used electrical tape to secure it to the new relay, then just slip it back over the post that secured the old relay in the same position.
Just put the seat and plastic piece back on the same way it came off and go ride
Just remember this is a constant rate relay so if a light bulb burns out your dash lights will still blink the same rate.
Check your bulbs every so often before a ride.
Hope this helps
ID:	2900   Click image for larger version
ID:	2901   Click image for larger version
ID:	2902   Click image for larger version
ID:	2903   Click image for larger version
post #3 of 20 Old 04-04-2005, 01:14 PM Thread Starter
1rocket69's Avatar
I couldn't figure out how to seperate the words and pictures so they just got bunched up together, if someone here (EL-D, ysr50) wants to spread them out so it looks better feel free.
post #4 of 20 Old 04-04-2005, 02:24 PM
MAVRIK's Avatar
Fine Job....
Everyday is a holiday, every meal is a feast
MAVRIK is offline
post #5 of 20 Old 04-04-2005, 03:33 PM
bluedevil's Avatar
Here is the 10min parts list. With this setup you can revert back to the stock relay setup, because you are only tapping into the stock wires and removing the stock relay. Some people might want a better connection like soldering but I fiqured if I have to constantly check for bulbs out anyway then why not splice.
flasher
bluedevil is offline
post #6 of 20 Old 04-04-2005, 08:44 PM
wow. A side benefit. I bet because your lights are flashing slower, your pulling less amps off of your alternator so there is less parasitic draw on the engine so new flasher=50 more hp. lol.
green 10r, Akro EVO 2, Hyperpro rsc, tre, pcIII, Puig DB, K&N, Purvision HIDs, Speedohealer, GONE
08 Ducati Hypermotard S GONE
08 Kawi Concours 14, Area P full sys, PCV, Flies out
speedfreak is offline
post #7 of 20 Old 04-04-2005, 09:12 PM
crispin's Avatar
Send a message via AIM to crispin
nice write up!
ya ya ya...
crispin is offline
post #8 of 20 Old 04-04-2005, 11:07 PM Thread Starter
1rocket69's Avatar
Thanks, I don't know how EL-D did so many, it took me longer to resize all the pics and write it up than it took to replace the relay. Notice the 3 hrs between the two write-up, yea I about head butted the computer , right when I was almost done the friggen thing locked up and I lost the second writeup , had to resize all the pics again had to take a break and drink a beer I don't have the patience to deal with stubborn computers
post #9 of 20 Old 04-05-2005, 10:31 AM
MAVRIK's Avatar
EL is very patient...
MAVRIK is offline
post #10 of 20 Old 04-07-2005, 02:36 AM Thread Starter
1rocket69's Avatar
Does this not rate a move to the How-To section?
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
New Mods w/pics... Heavy Duty flasher relay??? morrisjl2 The ZX-10R 26 12-11-2004 08:32 AM
replacing the tach Older Guy The ZX-10R 22 06-23-2004 12:30 AM
You may not post replies
