just did sparkplugs... wasnt that bad! TIPS! - Kawasaki ZX-10R.net
post #1 of 1 Old 12-17-2006, 08:15 AM Thread Starter
10 speed's Avatar
ok so i knew the spark plugs on the zx-10r were as dreaded as they come. I knew that in the top "reasons i own a 10" this was not on there.
step 1: admit it this will take some time...not a pain in the ass just takes some time.
step 2: strip your bike all fairings but the tail and ones around the head light but all side/lower/seat/tank got to go!
step 3: Remove the air box {remember counter clockwise}
ok so now is where it gets tricky! but easy! see the motor mounts on the side? they are triangles take those off! dont worry the motor has 2 other mounts that will hold it.
step 5: now that those are out of the way look on the bottom of your frame where those mounts were. AHHH HAAA! there is those 2 pieces of metal that are all kinda in your way. 2 12mm bolts and 1 14mm bolt and both are outa there! now you can use a swivle socket and a extension and remove all your plugs.
REMEMBER on reinstalling plugs a tid bit of anti size or grease on the threads is a good idea.
Your done put that shit back together and go riding! And remember extra nuts and bolt not cool!
I got tiered of buying go fast parts.... So i got a turbo! now i need go slow parts!
If it aint modded it aint yours!
10 speed is offline
just did sparkplugs... wasnt that bad! TIPS! 10 speed Performance and Tech 22 04-25-2007 05:34 AM
What's up with the sparkplugs, periodic maint? conspiracy Performance and Tech 18 09-23-2006 06:25 AM
brisk sparkplugs? busa41 Performance and Tech 0 01-09-2006 07:49 PM
glad my bike wasnt there.... 05ZixxR The Out House 25 11-29-2005 07:00 PM
Sparkplugs... slav Performance and Tech 7 10-04-2005 09:46 PM
You may not post replies
