how to remove secondary butterflies - Kawasaki ZX-10R.net
post #1 of 2 Old 02-09-2008, 10:55 AM Thread Starter
inappropriate
hesaves0211's Avatar
Images: 67
Okay, so many of you may already have a TRE unit, you should still consider this simple mod. After conversing back and forth w Garth and Redline i decided to go ahead and do this. Its simple, straight forward and can be done within an hour.
First things first, remove your tank and air box. which is by far the most time consuming part of this task. If you don't know how to do this search other threads and become well acquainted to the procedures for future maintenance.
DISCLAIMER NOTES:
This particular Mod standing alone or in combination with other performance enhancing Mod's is in need of thourough testing, ie dyno time with before and after A/F ratio readouts to give verifiable documentation of its worth or not and may ultimately require a custom map costing more $$$. If you notice your bike is running lean or rich failure to take action could result in damage to your motor. I didnt retune my map because i was running a little rich to begin with. However I will custom tune it this summer. I strongly believe a custom tune is good for any bike regardless of its mods in order to achieve peak performance.
This particular how-to applies to the 1st gen however, and while the following gens use the same principle there may be some minor detailed differences. It has been noted that the second gen's screws are highly torqued and often strip out.
What you'll need:
-#2 Phillips head screw driver *magnetic may help*
- needle nose pliers (to help remove the butterflies from their location, and if you drop a screw)
Once you get the air box out of the way you'll be able to clearly see what is known as the secondary butterflies (the top set is the secondary):
*this is not from a kawi but to give you an idea*
Then you'll carefully remove the two screws securing the valve from each port. Don't sweat it if you drop a screw or valve, that's where the pliers come in. If you'd like to play it safe tuck some paper towels into the throttle body housing to catch anything that may fall. *Apparently the second gen's screws are held in w loctite exercise caution to avoid stipping them out
if you've ever noticed the buzz when you turn you key "on" its the fuel pump priming along with the exhaust valve closing and secondaries opening i.e.
all but one valve has been removed in this picture.
the following pictures are obviously with the bike turned off:
please excuse my mechanic, he is still in training
the finished product:
and a bag of butterflies
here's a dyno chart and my research, compliments of Garth:
[/quote]
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #2 of 2 Old 03-26-2008, 08:41 PM
Andy's Avatar
Images: 25
Andy is offline
how to remove secondary butterflies hesaves0211 Performance and Tech 790 09-28-2014 08:12 PM
Removal of Secondary Butterflies ?? WRECKSHOP Performance and Tech 21 10-21-2007 07:25 AM
secondary butterflies and actuator hongthaomurphy Performance and Tech 13 07-16-2006 07:09 AM
Secondary Butterflies miykl Performance and Tech 96 01-13-2005 09:12 AM
You may not post replies
