How To remove KLEEN / AIS for Cal / 50st bikes - Kawasaki ZX-10R.net
post #1 of 80 Old 04-18-2004, 06:35 PM Thread Starter
Big Daddy's Avatar
Images: 38
The following instructions are not detailed to the extent some would like but they are sufficient enough to get the job done for the vast majority.
KLEEN /AIS removal procedure:
It's a pretty straight forward job using some basic tools once the seat, black side panels (2), gas tank, and both side body panels are removed for easy access to the solenoid, charcoal canister and associated hoses, it does of course require removing the airbox, and that itself requires an interesting method as the airbox is shoehorned into the spars and can be rotated counter clockwise in conjunction with pushing the rubber air intake boots forward making for the necessary room to remove it.
To remove the AIS/KLEEN solenoid, you’ll need the following:
(1) 5/8th vacuum cap (primary solenoid feed from airbox base plate)
(2) 3/8th vacuum caps (or appropriate reed block off plates)
To remove the charcoal canister (and related hardware), you’ll need the following:
(2) 1/8th vacuum caps (throttle body lines)
(1) 3/16th vacuum cap for the red tank inlet (charcoal canister/fuel tank feed – 1/4th caps may be applicable)
(1) suitable hose (perferably the hose with a blue stripe) connected to the blue tank inlet nipple and routed inside the RH frame rail and across the backside of the throttle bodies, then insert a 'T' fitting into it so that the OEM tank vent hose & overflow hose can be connected into the other 2 ends of the 'T' fitting so the tank vents properly.
Band / compression clasps, zip ties, hose clamps throughout (where applicable), are essential in order to seal the vacuum caps.
Big Daddy is offline
post #2 of 80 Old 04-18-2004, 07:34 PM
Cool. Thanks for the information, BD. FWIW, Dan Kyle has the block-off plates. They are the same as the 636 plates and under $30. Just got mine in the mail this week, but will install this week.
CanyonCarver is offline
post #3 of 80 Old 04-18-2004, 07:39 PM Thread Starter
Big Daddy's Avatar
Images: 38
Yeah the plates are by far the cleanest setup but using the plugs gives the same results so its nice to have a choice.
post #4 of 80 Old 06-09-2004, 04:11 AM
vane's Avatar
Re: KLEEN / AIS removal procedure for Cal / 50st bikes
(1) 3/16th vacuum cap for the red inlet (charcoal canister/fuel tank feed – 1/4th caps may be applicable)
(1) suitable hose (perferably the hose with a blue stripe) connected to the blue inlet and routed inside the RH frame rail and across the backside of the FI bodies, then insert a 'T' fitting into it so that the tank vent/overflow hose can be connected into the other 2 ends so the tank vents properly.
Sorry no pics as i don't have a digi. :(
My doctor said that I'm allowed one stupid question per day, so here's today's question.
What is the AIS / KLEEN? What does it do and why do you remove it?
I know nothing about bikes!
vane is offline
post #5 of 80 Old 06-09-2004, 08:59 AM
dnwhoop02's Avatar
Are there any ill effects of using the block off plates? The KLEEN system is just an emissions control component, so disabling it won't affect performance or anything, will it?
David Nolden
CMRA #711
dnwhoop02 is offline
post #6 of 80 Old 06-09-2004, 10:09 AM Thread Starter
Big Daddy's Avatar
Images: 38
The plates would be the better setup if you have them or plan to purchase them (at the time they were not available yet so......) The disconnecting of the KLEEN components will not effect performance.
post #7 of 80 Old 06-12-2004, 11:12 PM
Turtle's Avatar
Thanks more usefull info.
95' ZX9R
02' GSXR600 Race(sold)
03' YZ450F(sold)
04' ZX6RR Race
04' ZX10R
08' ZX10R
03'-04'WSMC #716
MRA #716
Turtle is offline
post #8 of 80 Old 06-14-2004, 09:37 AM
dnwhoop02's Avatar
have you installed these yet? If so, did they do the trick?
David Nolden
CMRA #711
post #9 of 80 Old 06-14-2004, 01:44 PM
Yep, and yep. :)
A pic for your viewing pleasure:
post #10 of 80 Old 06-14-2004, 02:09 PM Thread Starter
Big Daddy's Avatar
Images: 38
those look like pics of a pw 50 :P
Gasket and Cam Install BNninja How To... 42 04-08-2005 09:55 AM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
You may not post replies
