How To Install a Manual Fan Switch ZX10R 04/05 - Kawasaki ZX-10R.net
post #1 of 8 Old 06-23-2005, 02:35 AM Thread Starter
OmegaX's Avatar
I read the other posts that talk about doing this but the pictures will not display. My question is were are you tapping into the wires?? Please post some pix if you can. I want to make sure I get this right.
OmegaX is offline
post #2 of 8 Old 06-23-2005, 10:02 AM
Send a message via Yahoo to rtninja04
come off the fused side of the fan fuse 15a(under seat) with a wire. attach it to one side of a (single pole/single throw switch) attatch another wire from the other side of the switch to the blue wire going to the fan. use proper wires and switch
current bikes
2004 kawasaki zx10r
2005 honda shadow aero 750
1983 honda nighthawk 550
rtninja04 is offline
post #3 of 8 Old 06-23-2005, 07:53 PM
morrisjl2's Avatar
I was hoping I could post this pic from what I did but I guess the puter is smarter
than I am here is the best I could do. I used "manage attachments"
but that is as far as I could go. I am sure it will be up soon from some of the
puter guys on here.
If.................this works just plug into these wires right under your seat and run
them to your desired location to a "TWO PRONG" switch. Let me know if you need
any more help.
morrisjl2 is offline
post #4 of 8 Old 06-23-2005, 07:54 PM
morrisjl2's Avatar
What the Heeeeck.... it worked. don't know. good luck
post #5 of 8 Old 06-23-2005, 08:00 PM
morrisjl2's Avatar
BD...don't want to step on anyone's toes her but this needs to be put in the how to.
I want to say this has been the second time I have
put this up for you guys. just a suggestion. ????
post #6 of 8 Old 06-24-2005, 12:30 AM Thread Starter
OmegaX's Avatar
Thanks for the Picture. I see how to do it now. It looks like a 5min job
OmegaX is offline
post #7 of 8 Old 05-19-2006, 02:39 PM
SpeedyCorky's Avatar
Send a message via AIM to SpeedyCorky
ok ... 2nd stupidest question asked on this board (allready asked the 1st stupidest)...
morris, you are speaking of tapping into each of those wires and connecting them via a toggle switch, so that when the switch ON, then the fan will be ON; and when the switch is OFF, then the current wil not run between the 2 wires (just like stock) and the fan will remain operation via stock settings
so basically, crossing the blue and the green wire will cause the fan to go on.... correct?
... and yeah, this shoulda been put up in the 'how to' section a long time ago...!
- SpeedyCorky (stoppie addict) aka Charlie
* Support NASA!!! They are currently our only hope in getting off this rock. Help SETI find ET!!!
* The race is long, and in the end - it's only with yourself.
* In real life, the tortoise gets smoked.
SpeedyCorky is offline
post #8 of 8 Old 05-19-2006, 04:42 PM Thread Starter
OmegaX's Avatar
SpeedyCorky, you are correct. When the toggle switch is on the fan is on. When the toggle switch is off the fan operates as it normally would, as the temps change it will turn on and off by itself.
OmegaX is offline
04/05 ZX10R Rear suspension mod wstaab Performance and Tech 106 01-19-2015 08:52 AM
Manual fan switch , how to?? OmegaX Performance and Tech 14 05-19-2006 06:45 PM
How does one wire a switch turn on the radiator fan ? SpeedyCorky The ZX-10R 5 05-17-2006 08:41 PM
04/05 ZX10R Hydraulic Clutch Conversion? Larry Grogan The ZX-10R 11 02-22-2006 10:23 PM
Manual Fan Switch morrisjl2 The ZX-10R 3 10-12-2004 02:14 PM
You may not post replies
