How to: Install a 520 Conversion Chain and Sprocket set - Kawasaki ZX-10R.net
post #1 of 1 Old 04-14-2006, 12:49 PM Thread Starter
sumjoeguy's Avatar
I can't post this in the how-to section but check it out- may be helpful
http://www.sumofallparts.net/install/installkit.pdf
It's a PDF file you will need Adobe Reader to open it.
There are some other minor things on the ZX10R that need to change- like the torque specs on the countershaft nut and the gearing. For example, if you have a front and a rear on the 10R that use a number divisible by 3 (such as 15/45 or 16/48 etc) and the chain is an even # of links AWAY from stock length (say 112, 116, 120 etc of links) you will find that the master link will hit the rear sprocket on exactly the same spot every revolution and it will cause premature wear--> and fast. It's more problematic because of the very small rear sprocket and longer swingarm on the rear of the ZX10R.
Other than that, the information provided is pretty good for ZX bikes.
sumjoeguy is offline
Ok, my front sprocket was easy... -install with pics El Diablo Performance and Tech 122 04-02-2015 03:51 PM
How to: Install a 520 Conversion Chain and Sprocket set sumjoeguy The ZX-10R 3 04-14-2006 01:34 PM
Chain/ sprocket question VegasZX10R Performance and Tech 50 08-13-2005 10:40 AM
520 conversion talk Lyzic Performance and Tech 8 03-23-2005 02:13 PM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
You may not post replies
