"How To" Clean Brake Calipers - Kawasaki ZX-10R.net
post #1 of 7 Old 03-09-2007, 05:32 PM Thread Starter
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
Ok I am doing this how to because a few members requested it so since this is my first one take it easy on me.
First off you will need these things to get the job done. Brake cleaner, tooth brush, some rags, and a 5 & 6mm T-handle hex tool.
zx10ragentblack is offline
post #2 of 7 Old 03-09-2007, 05:37 PM Thread Starter
Yankee Racer
Images: 9
First remove the 2 calipers bolts with a 6mm hex tool. As you can see in the second pic it is a little dirty but can get far worse if you dont do this every now and then.
post #3 of 7 Old 03-09-2007, 05:41 PM Thread Starter
Yankee Racer
Images: 9
Next, we are going to want to remove the pads and to do so you need to remove the pics holding the pads in with a 5mm hex tool.
I also put the pads and pics back together the way I took them out for reference so you dont get confused when you put them back together. I also clean off the pins and pad spring before I put it back together.
post #4 of 7 Old 03-09-2007, 05:45 PM Thread Starter
Yankee Racer
Images: 9
Then you will need to pump the front brake lever to push the pistons out of the calipers a little so you can clean them off better. Make sure not to push them to far out or they will fall out and brake fluid will be everywhere.
You can start to clean now and I try not to spray the brake cleaner directly on the pistons as there are seals underneath and that can ruin the seals. So spray around it or just on the tooth brush. Make sure to get around the whole piston and wipe with a rag. I also clean off the entire caliper to make it look almost as good as new.
post #5 of 7 Old 03-09-2007, 05:47 PM Thread Starter
Yankee Racer
Images: 9
When you are done cleaning push all the pistons in as far as you can so the pads are easy to install.
Install the pads making sure the pin goes through pad, pad spring and then pad again and tigthen with a 5mm hex tool.
post #6 of 7 Old 03-09-2007, 05:49 PM Thread Starter
Yankee Racer
Images: 9
Mount the caliper back onto the bike by tightening the 2 6mm caliper bolts and you are good to go. Make sure to pull the lever to get the pistons and pads back into contact with the rotor or else the first rdie may be interesting without any brakes right away. Enjoy!!!
post #7 of 7 Old 03-25-2007, 01:55 AM
Administrator
YSR50's Avatar
Images: 32
Discuss this here: https://zx-10r.net/forum/showthread.php?t=35189
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
--Dr. Seuss
YSR50 is offline
"How To" Clean Brake Calipers zx10ragentblack Performance and Tech 30 04-24-2008 09:41 PM
Why does the rear brake res. line look so "weird" PatrickG Performance and Tech 9 04-05-2006 10:46 AM
"Sunstar" brake disc carriers?!? Rubber Pants The ZX-10R 3 06-18-2005 12:09 PM
"""gear indicator gauge....Who got Em """ Vonstallin The ZX-10R 17 03-22-2005 09:48 PM
You may not post replies
